Thread: 2007 T5 2.5 TDI PD engine - rising oil level
  1. 2007 T5 2.5 TDI PD engine - rising oil level
    Mar 2016
    Minervois, France
    53 Post(s)
    My son has had a 2007 T5 Multivan for several years, and lives in Copenhagen.
    Over the last couple of years he noticed that the oil level had risen slightly between changes.
    The van is mainly used for fairly short journeys, to work and back, about 12 miles each way, in city traffic.
    On the latest change, yesterday, he reckoned the volume drained was over 8 litres, when the full volume should be 7.5 litres.
    The van has never lost any coolant, and he believes the gain is due to oil dilution with diesel fuel - possibly because of the extra fuel injected during DPF recovery?
    I worked with this type of injector on GM engines many years ago, and remember that sometimes they leaked into the cylinders.
    I also suggested that moisture condensation in the crankcase could be the problem, but it does seem a rather large volume to be condensed water.
    Has anyone here experienced fuel dilution or crankcase condensation on this scale with this engine?
    I have suggested he gets a sump oil analysis asap, and meanwhile also checks the crankcase ventilaion system, as, if working properly, I would expect that to get rid of both water and diesel fuel in the oil.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: 2007 T5 2.5 TDI PD engine - rising oil level
    1840 Post(s)
    Yes water pump failure can be an issue but the oil would be emulsified, fuel can get into the oil from leaking injector seals because of loose injectors and from a leaking tandem pump, get the oil analysed to find out for sure what is wrong.
  3. Re: 2007 T5 2.5 TDI PD engine - rising oil level
    Mar 2016
    Minervois, France
    53 Post(s)
    Thanks Crasher. I just spoke to him (lucky I have free phone calls to DK), and he will send for a sample kit to post to UK asap. I suggested this outfit :- Lube Oil Sampling & Analysis Kit - Oil & Fluid Sampling Equipment
    He said there is no sign of emulsion in the oil, which I think would be very evident with 1 part in 8.
    Is regeneration done on the PD engines just by over-fuelling?
  1. Oil level rising
    By Jonatanso in forum Polo - Derby - Lupo - Fox
    Last Post: 23-06-2019, 08:48 AM
  2. 2008 Audi A6 C6 2.7 TDI Oil level rising
    By Juicyy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2016, 07:36 PM
  3. Please Help 3.0 tdi oil level rising
    By OVI82 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-07-2014, 02:08 PM
  4. engine oil level
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 04:04 PM
  5. Engine rev's rising and falling when starting
    By blocko in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2007, 12:10 AM
