Thread: Speedo Needle Showing Slower than Actual Speed
  1. Speedo Needle Showing Slower than Actual Speed
    Jan 2019
    staffordshire
    Interesting one. I know speedos are usually 3 or 4 mph out but this should always be over the actual speed rather than under, right?
    Well mine seems to be under estimating.
    If i use cruise control and set it to 50 for example, the needle will be around the 46/47 mark.
    Ive enabled the digital speedo display in the MFD too and that matches up with the cruise control speed.
    Also downloaded a couple of GPS speedo apps and again they pretty much match up with the digital numbers.
    Is there a way to recalibrate the needle?
  2. Re: Speedo Needle Showing Slower than Actual Speed
    Feb 2014
    United States
    Might be a dumb comment but mine has ACC and wont get close to a vehicle in front and will hold a lower speed based on the distance you set.
    Sent from my SM-N950U using Tapatalk
  3. Re: Speedo Needle Showing Slower than Actual Speed
    1840 Post(s)
    Are you running original wheel and tyre sizes?
  1. speedo needle
    By judgeju in forum Golf MK6 - 2009 - 2013
    Last Post: 16-10-2012, 01:39 AM
  2. Please Help 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
    By bigtoe22782 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2011, 08:26 PM
  3. Speedo needle vibrates when ignition turned on
    By Bill Badger in forum Golf MK4 - 1999 - 2004
    Last Post: 26-07-2010, 10:44 AM
  4. Question speedo saying im going slower than i am
    By ellsmith88 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-10-2008, 10:41 AM
  5. Please Help Speedo showing incorrect reading
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2008, 12:40 PM
