Thread: 2003 a3 1.8 sport stiff gear lever
  1. 2003 a3 1.8 sport stiff gear lever
    Feb 2019
    Leicester
    I’m on the hunt for an a3 and I’ve found just the right car. I’ve spoken to the seller and asked if there’s any issues with it and he’s said the only thing he can point out is that the gear selector is stiffer than he thinks it should be. Obviously I don’t want to buy a car with big issue but if it’s an easy fix it’s no problem. Does anyone know what could be causing this? It’s a 2003 car with only 60,000 miles on it.
  2. Re: 2003 a3 1.8 sport stiff gear lever
    1837 Post(s)
    On a low mileage older car with the cable shift gearbox this is usually the cable connection pivot on the top of the gearbox, a good clean up and two new bushings (1J0 711 067 L) at £2.26 each is the cure and about half an hours work.
  1. Please Help 2003 A4 1.9tdi Sport semitronic gear issues.
    By Paul Archibald in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2014, 03:49 PM
  2. DSG Gear Lever
    By thorne in forum Golf Plus
    Last Post: 06-07-2012, 03:35 PM
  3. DSG Gear Lever Replacment
    By Pugwash24 in forum Golf MK5 - 2004 - 2009
    Last Post: 25-07-2009, 01:03 AM
  4. Please Help Replacing/Removing Golf Mk5 Handbrake Lever Cover & DSG Gear Lever/Surround ?
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2009, 04:50 PM
  5. Question Gear lever console
    By Bagel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2008, 06:42 PM
