Thread: T5 ATE Abs Bleeding advice needed please ?
Results 1 to 10 of 16
  1. Post T5 ATE Abs Bleeding advice needed please ?
    I have recently replaced my ATE Abs pump and controller on my 2004 2.5tdi AXE T5 transporter and I'm looking for some advice on bleeding the brakes ?
    Are there any specific procedures that need to followed and is VCDS input required ?
    Any help would be greatly appreciated.
  2. Re: T5 ATE Abs Bleeding advice needed please ?
    1836 Post(s)
    A diagnostic system capable of Basic Settings is imperative and a pressurised brake bleeding system is almost as important, without both and knowing what to do, you will not get the air out.
  3. Re: T5 ATE Abs Bleeding advice needed please ?
    Thanks crasher, I have vcds so will obtain a pressurised bleeding kit and see how I get on.
  4. Re: T5 ATE Abs Bleeding advice needed please ?
    Is is just a case of following the procedure on vcds or are there any other tricks I should know about ?
  5. Re: T5 ATE Abs Bleeding advice needed please ?
    1836 Post(s)
    It depends on if it is a Mk20, 25 or 60 system.
  6. Re: T5 ATE Abs Bleeding advice needed please ?
    It’s a MK25 system.
  7. Re: T5 ATE Abs Bleeding advice needed please ?
    1836 Post(s)
    Off the top of my head, like the Mk20, you have to go through the full 17 step on screen process because if you don’t the ABS stores a permanent no basic settings code and leaves the light on, the Mk60 doesn't do this. When it says to hold the pedal down, be ready for the kick back which can actually lift you out of the seat, if the pedal kicks back unresited it can do damage. You will know if it is like this if after clicking go it changes from 1 to 2 and so on rather than just staying at 1.
  8. Re: T5 ATE Abs Bleeding advice needed please ?
    I’ve done this today using VCDS and it only allows me to go through the first step.
    Brakes have improved but still feel they could be better, am I doing something wrong ?
  9. Re: T5 ATE Abs Bleeding advice needed please ?
    1836 Post(s)
    Oddly the ELSA manual does not specify the basic settings bleed so I think it is just the one step and I do this around four times, this is the official procedure for a soggy pedal
    Subsequent bleeding of hydraulic system
    Carry out subsequent bleeding when:
    brake pedal travel is too long or so-called »soft brake pedal«
    This requires the assistance of a second mechanic:
    Depress brake pedal firmly and hold.
    Open bleeder valve on rear right brake caliper.
    Fully depress brake pedal.
    Close bleed valve with pedal held down.
    Release brake pedal slowly.
    This bleed sequence must be carried out 5 times per brake caliper.
    Bleeding sequence:
    1. Front right brake caliper
    2. Front left brake caliper
    3. Rear right brake caliper
    4. Rear left brake caliper
    A road test must be carried out after the brakes have been bled. When doing this an ABS regulation must be performed at least once!
    The triggering of the ABS is the important thing, you will be amazed at how effective it is BUT take care etc.
  10. Re: T5 ATE Abs Bleeding advice needed please ?
    Thanks Crasher. I will try the suggested procedure tomorrow, fingers crossed.
  1. Please Help Bit of advice needed....
    By Pete_NorthEast in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-05-2018, 02:24 PM
  2. Advice needed, 56 vs 57
    By Lewis-Oddie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-05-2014, 08:10 AM
  3. Advice needed 2.0t fsi
    By delrington in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-07-2010, 10:50 PM
  4. Looking to buy an S6, advice needed
    By TrevS in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-01-2010, 03:10 PM
  5. Please Help Advice needed
    By djbarren in forum Touran - Sharan - Caravelle
    Last Post: 08-08-2009, 11:06 PM
