Thread: Heater Running Hot
  1. Heater Running Hot
    Feb 2019
    Bognor Regis, UK
    I have an issue with my 1.8TFSI Cabriolet which interestingly I couldn't find posted anywhere on the forum - the heater sometimes runs hot irrespective of what temperature the displays are set to. Lots of posts with heaters only blowing cold air but not the other way round! Even on 16degC the vents blow hot air and the only way to stop it is to turn the A/C on. It doesn't always do it and when I've read the fault codes so far nothing is showing a stuck flap or valve or anything...
    Anyone seen this before who can point me to what it is?
    Thanks!
  2. Re: Heater Running Hot
    Mar 2016
    Minervois, France
    28 Post(s)
    I had the same problem on my A4 B5, decided the flap for hot air, V68, must have been sticking occasionally.
    I performed the basic settings while watching the flap motor and lever, and eventually saw it stick slightly open.
    I managed to get the motor out with the heater assembly in place with only a few cuts and gashes on my hands.
    I dismantled and reassembled the motor, but couldn't see anything wrong with it and it worked OK whilst hanging on the wires.
    I put it back in, but it stuck again, so I replaced it with a new motor, found on Ebay, and it now works fine.
    It was a bit expensive, 120, but it's so hard to get the motor in and out I didn't risk fitting a used one.
    1996 A4 Avant 1.8T engine code AEB automatic with 58,000 kms - 36,000 miles on 1/1/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  3. Re: Heater Running Hot
    Feb 2019
    Bognor Regis, UK
    Great - I'll take a look and see what I find. Many thanks for the tip!
  1. Question Disconnecting heater duct from heater case behind glove box
    By DH1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-11-2018, 10:09 PM
  2. Replies: 3
    Last Post: 03-11-2016, 02:20 PM
  3. Great heater performance, does my B6 have an aux heater fitted?
    By andrewturner in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-11-2011, 12:38 AM
  4. Heater slow / Auxillary heater
    By Phil her up in forum Alhambra
    Last Post: 01-12-2010, 10:51 AM
  5. Running a portable heater off the cigarette lighter
    By Jasonz in forum Golf MK4 - 1999 - 2004
    Last Post: 12-09-2009, 08:20 AM
