Thread: ECU faullts & repairs ?
Results 1 to 10 of 10
  1. ECU faullts & repairs ?
    Jun 2016
    Devon
    Moving on from the humidity problem which is slowly improving, I still most likely have a problem according to my classic crazy local garage with a faulty ECU unit instead and that it most likely needs repairing as new ones are very expensive. This is because the oil lamp icon in the top left hand corner of the instrument cluster keeps returning and they're still not sure what's causing it.
    Haven't a clue myself either so any thoughts or suggestions beforehand would be most welcome....
    1982 Type 43 Audi 100 GL5E
    1984 Type 43 100 CS two tone
  2. Re: ECU faullts & repairs ?
    Apr 2018
    N.Ireland
    9 Post(s)
    Is it a Diesel B6?
    Edit just checked the previous post, if your stuck buy an ecu of the same number and have it IMMO off
  3. Re: ECU faullts & repairs ?
    Jun 2016
    Devon
    No it's a 2 litre FSI petrol. Apols but what's an IMMO ?
  4. Re: ECU faullts & repairs ?
    Sep 2008
    chester
    17 Post(s)
    Is it the oil level or oil pressure warning?
  5. Re: ECU faullts & repairs ?
    Jun 2016
    Devon
    No idea what this means but this is the symbol I've been fed up with regularly seeing since I bought the car 18 months ago. This might even be causing the remote key fob to stop working as well for all I know....
  6. Re: ECU faullts & repairs ?
    Sep 2008
    chester
    17 Post(s)
    That is a engine management fault,you need to get it scanned to see the faults and report back,if you've got high humidity levels its leaking into the cabin.
  7. Re: ECU faullts & repairs ?
    Jun 2016
    Devon
    Thanks. The garage said it meant it was something to do with the ECU unit and needed to be sent away to be repaired, having already replaced one relay in it as I said earlier that had gone green around its base.
    This is why I was wondering what they cost etc. and what to do....
  8. Re: ECU faullts & repairs ?
    Sep 2008
    chester
    17 Post(s)
    very expensive new,get a quote from bba reman for a repair,also do you know what they used to scan the vehicle,you need something decent to get a meaningful answer I would ask what exactly the fault stored say's.
  9. Re: ECU faullts & repairs ?
    Jun 2016
    Devon
    Ok see what they say thanks....
  10. Re: ECU faullts & repairs ?
    Jun 2016
    Devon
    Quote Originally Posted by JimA4B6 View Post
    Is it a Diesel B6?
    Never having heard of it before just Googled IMMO off and realised why you mentioned it sounding ideal, so surprised the garage hasn't heard of it in view of the costs possibly involved. I'll mention this on Monday as well as getting a meaningful answer thanks....
    VW AUDI IMMOBILISER OFF BYPASS IMMO DEFEAT | ECU/CLUSTER LOGIN | EDC15: Amazon.co.uk: Business, Industry & Science
  1. Possible repairs?
    By toxpal in forum A7 - S7
    Last Post: 21-12-2017, 09:53 PM
  2. In for repairs
    By slope in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-08-2012, 08:57 PM
  3. lcd repairs
    By raver100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-09-2009, 09:16 PM
  4. Please Help TDi sluggish after repairs
    By markiparki in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2008, 10:20 PM
