Thread: TT 225bhp quattro (2001) clutch pedal
  1. TT 225bhp quattro (2001) clutch pedal
    Jun 2012
    Surrey
    My TT had a new clutch and flywheel about 12000 miles ago, the previous owner tells me since then the pedal is very close to floor to disengage. It drives great, has a nice clutch action and does clear fine but it is virtually on the floor to do so.
    There is quite a lot of free play at the pedal before it even starts to push the master cylinder rod. How much free play should there be?
    I can see the pedal fitment move along the pushrod before it then starts pushing it and have checked the pushrod is fully out, it does not pull back any more so it is not sticking in the master cylinder.
    No signs of fluid leak at either end.
    It does not feel spongy in any way but I will bleed the system well with new fluid, am I correct in that the fluid is shared with the brakes..so top that one up as I bleed.
  2. Re: TT 225bhp quattro (2001) clutch pedal
    40 Post(s)
    899 Post(s)
    Did it have a new real bearing fitted? It would be worthwhile having the hydraulic system bled.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  1. Clutch Pedal or Clutch and Pressure Plate Issue?
    By steamship in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-02-2019, 05:54 PM
  2. Replies: 0
    Last Post: 03-02-2017, 04:10 PM
  3. Worsening Mechanical Noise from Clutch Housing When Depressing Clutch Pedal.
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-07-2013, 08:37 PM
  4. AUDI TT 2001 225bhp Turbo replacement
    By Rossco250 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-01-2013, 04:55 PM
  5. Clutch pedal needing adjusted or Clutch on way out?
    By rossvwp4m in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2010, 05:57 PM
