Hi guys, i have a real odd one here...
I have an S reg polo with a radio issue....
When i put the key in and turn it to the 1st position the radio comes on and works normally... turn it off and the radio stays on until you remove the key... thats fine and works as it should...
However..... and this is the wierd bit... turn the key to position 2 and the radio turns off!
The engine will start and run as normal and the car drives, but there is no power to the radio until you turn the car off again!!!!
anyone come across this before? its not the radio as i have replaced this just incase.... im not sure how this wired to the ignition switch, but surely if the 2 position turns the car electrics on then the radio should be on too!!! exverything else works in the car (except the fan on position 1&2 but thats another thread)
Thanks in advance!
