Thread: Adaptive Light Error Started
  1. Adaptive Light Error Started
    Jun 2006
    Hi everyone,
    Hoping someone can help shed some light on an error that popped up a couple of days ago. The error came up on a long journey after I went over a bumpy road. Went away when I restarted the car.
    Looking at VCDS (genuine version) this is the info before I cleared the codes:
    Wednesday,13,February,2019,14:09:38:53639
    VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
    www.Ross-Tech.com
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Control Module Part Number: 4F0 910 357 C HW: 4F0 907 357 C
    Component and/or Version: AFS 1 H01 0020
    Software Coding: 0000016
    Work Shop Code: WSC 00097 210 90088
    Additional Info: 4F0941329A AFS-Modul links H05 0010 4F0941329A AFS-Modul rechtsH02 0020
    VCID: 264312DD91368A7A87-8072
    1 Fault Found:
    01771 - Control Module for Headlight Range (J431)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 152168 km
    Time Indication: 0
    Date: 2019.02.11
    Time: 10:25:17
    After I cleared the codes and before disconnecting it then came up with this:
    Wednesday,13,February,2019,14:11:58:53639
    www.Ross-Tech.com
    Address 55: Headlight Range Labels: 4F0-910-357.LBL
    1 Fault Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 152520 km
    Time Indication: 0
    Date: 2019.02.13
    Time: 14:11:14
    A few weeks ago a parking bulb in one headlight failed, this was changed by a specialist. Could it be something simple like a loose wire that was disturbed on the bumpy road, or the sign of something more serious and expensive. New headlights are not cheap so I'm hoping it's something simple.
    The initial error mentions the control module part number: 4F0 910 357 C, I will do some research on this, where it's fitted and how much a new one is, can see 2nd hand ones on ebay for £50.
    Also found out there is an associated level sensor that connects to the front NS suspension. As this moves and presumably wears, this could possibly cause the error. Will keep searching!!
    Thanks in advance for any help or past experiences with this.
    Andy
  2. Re: Adaptive Light Error Started
    Jun 2006
    I have resolved the issue, basically I needed to recalibrate the adaptive lights. Took only a few minutes, followed stage 2 of the guide below:
    DIY: How to Properly Re-Calibrate and Adjust Adaptive Bi-Xenon Headlights
    All credit to AlphaVR for this, really good guide and easy to follow, would have never worked this out without it.
    Just in case someone else has the problem.
  1. Important Car started shaking badly, lots of error codes
    By The Norwegian in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-06-2017, 08:41 AM
  2. Question Adaptive light fault
    By peter.metcalf72 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-11-2016, 05:02 PM
  3. Adaptive Light Defective
    By papadelta in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-07-2015, 04:35 PM
  4. Please Help A8 E3 dynamic cornering light, adaptive light not working
    By astrafax in forum A8 - S8 - V8
    Last Post: 15-12-2011, 10:25 PM
  5. adaptive light defective
    By a6c63lq in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2010, 01:05 PM
