Thread: EPC Light On and Off
  1. Exclamation EPC Light On and Off
    Feb 2019
    Nairobi, Kenya
    Hi Guys,
    I recently got myself a 2011 8P A3 Sportback S-Line 1.4T.
    I have had the car for about a month now, and I have noticed the EPC light coming on for a few seconds then going off. This has been happening on just normal driving to/from work.
    At times I have noticed a slight jerk / lag and the light comes on for a few seconds. Other times the light comes on when accelerating just normally.
    The spark plugs and coils have been changed but the same thing happens. There is no loss of power or anything when the light comes on, and no other lights come on. It has happened on different speeds like 30-40 km/h, 60-70 km/h and 90-100 km/h. I can just be cruising on the highway and the light comes on.
    Any help on what could be causing this will be highly appreciated.
    Thanks.
  2. Re: EPC Light On and Off
    20 Post(s)
    487 Post(s)
    These suffer from rear wheel bearing speed sensor ring corrosion which can send confusing signals to the ABS ECU which them thinks you are in a skid and uses the brakes to tweak the cars line and at the same time fash the ESP light to show it is doing something. Start with a code read, if none are stored it is likely it will need tow rear wheel bearings and speed sensors.
  3. Re: EPC Light On and Off
    Feb 2019
    Nairobi, Kenya
    Thanks for the prompt reply. You've mentioned the ESP light, but I'm getting the EPC light.
    The car is at the garage and I was told the Accelerator Pedal Sensor showed a fault and the battery voltage was also showing low. I guess that's what caused the EPC light to come on.
    It's being worked on and I'll post an update once I get the car back.
    Cheers.
  4. Re: EPC Light On and Off
    20 Post(s)
    487 Post(s)
    That's odd, I hadn't touch a drop at that time....
    The EPC light stands for Electronic Performance Control and is tied into the accelerator pedals output.
  1. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  2. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 03-05-2017, 10:27 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
