Thread: Indicators and Hazards not working
  1. Indicators and Hazards not working
    Brighton, United Kingdom
    On sunday night my right hand indicator at the front stopped working, all other indicators on the right hand side were fine and when I was indicating right I was getting the double quick flash, so presumed the bulb had blown. Today I went to change the bulb and when i removed it, it hadn't blown and was fine, so I plugged it all back in again to see if maybe it had just come loose and now none of my indicators are working including the hazards which had been fine before as I only used them on Sunday night as well! Any ideas? Fuse? Relay switch? My headlights are all fine and the stalk for the main bean lights still works fine, its just the indicators.
    Thanks in advance for any help you can give
    1.6 16v S W2000reg AUS .
  2. Re: Indicators and Hazards not working
    For anyone that has this problem and looks at this - when i replaced the bulb, it had for some reason blown all the light fuses!! Replaced the indicator and hazards fuses and now all working fine - except that now the indicators don't flash when you lock the car with the key fob?! Still haven't found a fix for this yet!
  1. Please Help Indicators/Hazards randomly flashing once intermittently when parked
    By leew1988 in forum Golf MK6 - 2009 - 2013
    Last Post: 20-08-2017, 09:36 PM
  2. erratic indicators & hazards - is haz switch the culprit ?
    By trevMk2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2009, 10:18 PM
  3. Indicators not working but hazards do !!!!
    By bigtroot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 10:22 AM
  4. mk4 golf GTI 2l turbo indicators/ hazards
    By iain c in forum VCDS - Help Requests
    Last Post: 27-11-2008, 12:35 PM
  5. faulty indicators and hazards
    By janem29 in forum Passat - Archive Topics
    Last Post: 28-06-2007, 10:20 PM
