Thread: BKP problem ** Advice Needed**
Results 1 to 10 of 20
  1. BKP problem ** Advice Needed**
    Jan 2019
    Ireland
    Hi all, so I recently bought a 2006 Passat with the 2.0 BKP engine.
    The car has had an ongoing issue since before purchase.
    The car drives very well and is no way hesitant throughout the rev range, the issue only arises when it is sitting ticking over.
    It seems to idle at at a very low RPM (almost like it finds a low idle if that makes sense?) and when it does this, it causes a shudder or a vibration of sorts.
    The problem is not there 100% of the time, but it certainly is there MOST of the time
    It is visibly noticeable in the engine bay when this is happening, the engine shakes excessively particularly around the upper left mount / alternator area ( as you look into the bay)
    A small blip of throttle and the shudder will go away for around five to ten seconds and then proceed to return.
    I have checked the alternator clutch pulley and it seems fine. I think I can rule out the DMF as clutching does not lessen or remove the shudder.
    Also, there are no warning lights etc showing on the dash.
    I would really appreciate some guidance as I'm stumped!!
  2. Re: BKP problem ** Advice Needed**
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by anthonyf5 View Post
    Ah the infamous B6 2.0 litre lumpy idle!
    There's a few things that could cause the vibration...
    Dirty / partially blocked injector.
    DMF wobble.
    Fuel contamination.
    Timing not adjusted to optimum level.
    Injector piston clearance excessive.
    Bad engine mount.
    More serious engine wear
    My idle is 750 hot, 800 at spring summer start up and 900 in very cold weather for a few minutes.
    Live data from a VCDS scan would help as you'll be able to look at idle stabilisation, health of injectors and other useful readings.
    Mad Mitch
  3. Re: BKP problem ** Advice Needed**
    1840 Post(s)
    Get a fault code read done, if nothing shows get them to check the injector balances. Open up the fuel filter and see if the fuel inside is black.
  4. Re: BKP problem ** Advice Needed**
    May 2012
    Everywhere
    308 Post(s)
    Also throttle body - plastic cogs .
  5. Re: BKP problem ** Advice Needed**
    Jan 2012
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Gazwould View Post
    And...say it Gaz...starts with '77'
    Mad Mitch
  6. Re: BKP problem ** Advice Needed**
    May 2012
    Everywhere
    308 Post(s)
    Yep , 77 toothed cog breaks but 100 tooth doesn't .
  7. Re: BKP problem ** Advice Needed**
    Jan 2012
    10 Post(s)
    87 Post(s)
    Anthonyf5 - what is your current mileage on the car?
    Mad Mitch
  8. Re: BKP problem ** Advice Needed**
    Jan 2019
    Ireland
    173,000 and going strong(ish)
    thanks for the replies and guidance chaps it's much appreciated.
    unfortunately I don't have access to VCDS, I can get the car checked locally this week but I think the guy uses a generic system and for the life of me I cannot remember the name.
    Would it be worth taking the rocker off to inspect the Injector loom, also , how problematic are the EGR's?
    This is my first B6 , had many a care free years in B5.5's so am relatively unfamiliar with these
  9. Re: BKP problem ** Advice Needed**
    May 2012
    Everywhere
    308 Post(s)
    Quite a big difference in reliability terms .
  10. Re: BKP problem ** Advice Needed**
    Jan 2019
    Ireland
    Night and day . But I'm only basing that on having owned this one B6, probably not a fair assessment. Had I went for one a few years younger I'd say it would be less problematic.
    Oh and I believe it's Delphi diagnostic software the guy is using?
  1. Air Con problem, advice needed.
    By TDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2018, 09:06 PM
  2. problem with engine advice needed please
    By les127 in forum The Commercial Range
    Last Post: 24-07-2015, 05:15 AM
  3. HID problem!! Advice needed.
    By Ballan. in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-01-2012, 10:31 PM
  4. Urgent help/advice needed. Big Problem
    By markcass in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2007, 07:52 PM
  5. brake problem - advice needed!
    By nik_codling in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 08:53 PM
