Thread: EML Light ????
  1. EML Light ????
    Feb 2019
    Runnymede, UK
    Hi All,
    The EML light came on. I had a diagnostic run on it and it came up with "V157 EGR Valve". A mate of mine was going to sort it but hasn't got around to it. Anyway, it was on for 4/5 weeks. The car drives perfectly. But now it's gone off. I first noticed it was off on Saturday and has been off ever since ???? Any thoughts ????
    Peter
  2. Re: EML Light ????
    Oct 2014
    Binfield
    6 Post(s)
    Likely the EGR was jammed and has become unstuck. Will probably come back if you havenít changed anything.
  3. Re: EML Light ????
    Feb 2019
    Runnymede, UK
    Quote Originally Posted by OliNix View Post
    I haven't changed anything. So I guess I just wait until it pops up again.
  4. Re: EML Light ????
    Oct 2014
    Binfield
    6 Post(s)
    I would suggest to clean out the intake as it is probably all coked up and that is causing the EGR fault.
  5. Re: EML Light ????
    Feb 2019
    Runnymede, UK
    Thanks, Ill give it a go. I was planning some maintenance/ spring cleaning this weekend. Do I'll pull it apart and see what I can break
  6. Re: EML Light ????
    Mar 2018
    GB
    16 Post(s)
    Powerenhancer | Largest Indepe...ckist of Fuel & Oil Treatments, AR6400-D 430 gives everything a clear through. Use EA189 as a discount code for 20% off. They do a service kit with an oil treatment as well.
    Sent from my SM-G950F using Tapatalk
  1. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  2. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 03-05-2017, 10:27 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
