Thread: Turbo gives up midway through journeys
  1. Turbo gives up midway through journeys
    Feb 2019
    Chesterfield, England
    Hi, new member and first time poster.
    My 08 plate Golf Mk5 diesel started playing up last week when the turbo seemed to just cut out part way down the motorway. It went into limp mode and while it still drives, it goes next to nowhere and really struggles at about 40mph up any sort of gradient. When I turn the engine off and back on again, the turbo comes back but only for a short while before dying again.
    I'd be happy to provide any more info you think is needed to diagnose this, but absolutely any help would be appreciated.
    Thanks.
  2. Re: Turbo gives up midway through journeys
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It's probably the turbo vanes sticking & causing overboost.
    But you do need a diagnosis with VCDS or similar diagnostics.
    Have a look on the VCDS owners map on here & see if there is someone nearby who would check it for you for beer money.
  3. Re: Turbo gives up midway through journeys
    Feb 2019
    Just found the diagnostic results from the RAC tech that came out:
    System Type: ENGINE SYSTEM TEST/VALUES
    Name: BKD - TDI - 2.0L - 103 (140)
    DTC: P0234,Charge pressure control; Regulating limit surpassed
  4. Re: Turbo gives up midway through journeys
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Mileage ?
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Turbo gives up midway through journeys
    Feb 2019
    Just clocked 126000 this morning
  6. Re: Turbo gives up midway through journeys
    1837 Post(s)
    Overboost, turbo rebuild time.
  7. Re: Turbo gives up midway through journeys
    Feb 2019
    Okay, thanks for your help!
  8. Re: Turbo gives up midway through journeys
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I would recommend Turbo Technics as a source for quality re-manufactured turbos.
  9. Re: Turbo gives up midway through journeys
    1837 Post(s)
    We use Midland Turbo, just down the road from you Ugmo.
  1. Is the 3.0 TDi really a bad idea for short journeys?
    By A4B6Cab in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 02-02-2017, 03:18 PM
  2. Question 1.6 tdi and short Journeys
    By TheMadhatter in forum Octavia
    Last Post: 10-03-2016, 02:12 PM
  3. Question which engine oil for short journeys
    By barrymorri in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2011, 03:28 PM
  4. One of those journeys
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-08-2011, 11:28 PM
  5. Question Loss of turbo early in journeys
    By mwhitehouse in forum Bora - 1998 - 2005
    Last Post: 23-01-2010, 07:08 PM
