Thread: Suspension dots identification
  1. Suspension dots identification
    Apr 2014
    SW London / Surrey
    Hi all
    It looks like a pothole might have got the better of the nearside front spring on our 2008 Touran (but posting here as more folk pass by and it's a very similar setup). A grinding noise started when steering , and a listen around tracked it to the top of the suspension mount. From a peek underneath it looks like the top section of the spring has broken off, so the spring isn't sitting in the cup / bearing correctly - and indeed that bearing is displaced into the spring (pic2).
    Main question is whether anyone can say if the dots on here are pink+yellow+green, or violet+yellow+green :
    Attachment 35707
    I'd have said pink, but looking at the online EKTA type resources I can't find a P-Y-G one so it seems likely to be violet and hence part 1K0411105HN for G24+L43 PR codes on the 2008, etc Touran. Can someone look those codes up if I PM reg / VIN?
    I understand the top bearing is a cheap part so probably worth replacing anyway, but in case it isn't in stock, etc does the displaced one below look reusable:
    Attachment 35708
    TIA
  2. Re: Suspension dots identification
    Apr 2014
    SW London / Surrey
    It's violet . VIN decode gives the G24+L43 PR codes, as per PR codes from VIN please.
  1. Pipe Identification
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-10-2017, 03:17 PM
  2. A4 B8 I.C.E identification
    By StuBeeDoo in forum In Car Entertainment
    Last Post: 02-09-2016, 12:05 PM
  3. New TT with tiny black dots on paintwork
    By garyizme in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 16-04-2016, 10:19 AM
  4. 4motion worn rear suspension bush, identification needed
    By ihs61 in forum Golf MK5 - 2004 - 2009
    Last Post: 22-03-2014, 09:28 AM
  5. ignore the dots
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-04-2009, 09:52 AM
