Thread: Drain Coolant?
  1. Drain Coolant?
    Jan 2019
    staffordshire
    Did a quick test on my coolant/anti-freeze today with a nifty gadget and looks like its only effective upto -7c. So ive ordered some G13 and will put that in when it arrives. Was just wondering is there an easy way to drain the existing coolant or shall I just empty the container that I can see and just top up from there? Not sure how much the container holds up to the min/max line but is probably enough to pump the temperature tolerance up?
  2. Re: Drain Coolant?
    1841 Post(s)
    Pull the bottom coupling off of the radiator
  1. coolant drain & flush
    By GARY in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2013, 08:21 PM
  2. Where is the coolant drain?
    By Spacer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2011, 01:02 AM
  3. Coolant Drain
    By NickPicks in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 12:16 AM
  4. How to drain coolant?
    By TeK in forum Golf MK4 - 1999 - 2004
    Last Post: 16-05-2008, 10:33 AM
  5. How to drain the coolant
    By n1kh3l in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2007, 10:22 AM
