Thread: Fuel Filter Change
Results 1 to 10 of 11
  1. Fuel Filter Change
    Feb 2013
    Uk
    37 Post(s)
    I’m going to change my fuel filter this week on my 2.0l diesel, once I’ve changed it , do I need to use VCDS to prime/bleed the system ?
    (I’ve had a look on the internet , but can’t find a definitive answer)
    Thanks in advance
  2. Re: Fuel Filter Change
    1840 Post(s)
    Yes, extremely important.
  3. Re: Fuel Filter Change
    Feb 2013
    Uk
    37 Post(s)
    Thanks Crasher - how long should I run the pump for ?
    thanks again
  4. Re: Fuel Filter Change
    1840 Post(s)
    When using ODIS it runs it for about five minutes so VCDS usually times out and the process has to be started a few times.
  5. Re: Fuel Filter Change
    Feb 2013
    Uk
    37 Post(s)
    Thanks again! Crasher - sorry to be pain , approx how long before it times out? Or shall I let it run for 30 seconds and repeat 10 times
  6. Re: Fuel Filter Change
    1840 Post(s)
    I think it times out after a minute. The pain is that sometimes VCDS will not allow you to carry out a further output test without exiting Engine 01 and momentarily attempting to start the engine!
  7. Re: Fuel Filter Change
    Tripletrouble Guest
    So without VCDS a DIY job is out then. Back to the dealer it is...
  8. Re: Fuel Filter Change
    1840 Post(s)
    You could hot wire the relay but it's a bit of a pain.
  9. Re: Fuel Filter Change
    Feb 2013
    Uk
    37 Post(s)
    Filter changed successfully , thx Crasher for your help!!!
  10. Re: Fuel Filter Change
    Tripletrouble Guest
    Just as an aside, when is the fuel filter due, mileage wise?
  1. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  2. 02 a4 3.0 fuel filter change
    By gymguy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-09-2013, 09:02 PM
  3. fuel filter change
    By ad777 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2010, 07:10 PM
  4. Change fuel filter
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-07-2009, 02:12 PM
  5. Need to change fuel filter on T5
    By SmithG in forum The Commercial Range
    Last Post: 03-09-2008, 08:53 PM
