Thread: High pressure pump ticking sound
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: High pressure pump ticking sound
    #21
    Jun 2019
    Tallaght
    Quote Originally Posted by vinee59 View Post
    But egr deals with exhaust gas not fuel injection... heard a brand new Passat today with the same ticking sound.
    Sent from my SM-G950F using Tapatalk
    Yeah. Just really odd it’s the same wiring loom. Didn’t have the issue before today, cleaned EGR now have the issue
    If I remove the cable from the HPFP the ticking complete goes away
  2. Re: High pressure pump ticking sound
    #22
    Feb 2019
    GB
    Yes that is because the valve isn't operating as normal, wonder if the problem is electronic related and not mechanic
  3. Re: High pressure pump ticking sound
    #23
    1840 Post(s)
    Quote Originally Posted by jackfirth1 View Post
    And now you have at least two fault codes stored in the ECU that are nothing to do with the problem and will slow down proper diagnosis.
  4. Re: High pressure pump ticking sound
    #24
    May 2015
    Washington UK
    I have the exact same problem with my 2009 mk6 golf 2.0tdi I only got to test drive it in a car park and didn’t think to let the window down, the noise issnt audible at idle just when I drive, as described pull that plug on pump noise is gone but flashing glow plug and had to delete the codes after doing that, has anyone solved it yet without spending a fortune on it.
    Local mechanic said they all sound that way with these engines
  5. Re: High pressure pump ticking sound
    #25
    1840 Post(s)
    If you have a fault code you have to deal with it, there is no quick easy fix.
  6. Re: High pressure pump ticking sound
    #26
    May 2015
    Washington UK
    There’s no codes. I only got them when I unplugged the wire to see if it went away, I guess I’ll have to live with it for till it leaves codes
  7. Re: High pressure pump ticking sound
    #27
    May 2015
    Washington UK
    I noticed my car has had its timing belt done could it be the timing of the pump that’s out making that valve noisy?
  8. Re: High pressure pump ticking sound
    #28
    1840 Post(s)
    The CR TDI high pressure fuel pump is not timed.
  9. Re: High pressure pump ticking sound
    #29
    May 2015
    Washington UK
    Thanks for ur reply crasher I only asked about timing because I’d just watched a engine code CBDC timing belt change video on YouTube and the guy locked the pump pulley on that one. It can buzz away like others have said they are just gonna live with it I guess thanks again
  10. Re: High pressure pump ticking sound
    #30
    1840 Post(s)
    Yes you pin the pulley to stabilise the tension between the cam and pump pulleys so you set the tension between the crank and the cams, not in the complete system.
  1. Question Can a High Pressure Fuel Pump just fall off?
    By matapaca in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-07-2021, 01:10 PM
  2. Polo 2003 AMF engine overboosting and high pressure air sound
    By gkm24 in forum Polo - Derby - Lupo - Fox
    Last Post: 25-11-2018, 09:20 PM
  3. Audi B7 A4 2.0TFSI Quattro High Pressure Fuel Pump and Camshaft Failure
    By hal402 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2013, 10:31 AM
  4. High pressure Fuel Pump Problems on 1.6 TDI
    By bdb in forum Golf MK6 - 2009 - 2013
    Last Post: 17-12-2010, 10:25 AM
  5. High pressure fuel pump replacement I THINK?
    By MathewRB in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2008, 09:16 PM
