Thread: Audi A4 b7 54 plate in Limp mode
  1. Audi A4 b7 54 plate in Limp mode
    Feb 2019
    Scotland
    Hi guys ,looking to pick your brains regarding issues with my A4
    I have had it plugged in for diagnostic & the following codes came up
    19462
    Power stage,High heat ,short circuit to ground / open circuit- PERMANENT
    17994
    Engine mount solenoid valve ,short circuit to plus - INTERMITTENT
    16618
    Charge pressure control
    Regulating limit surpassed
    My reasoning behind getting a diagnostic done ,was because my car keeps going into Limp Mode..
    It first happened 3 weeks ago when taking a gentle drive to work ,then was ok when I went to drive home ?
    Now in the last week it has happened twice ,once when I was overtaking & the 3rd time in low gear take off in the morning going to work ,on my journey home it happened again .So I have parked the car up and refuse to use it ,in case I occur a bigger problem .
    Are the possible problems :- a split intercooler hose ,faulty glow plugs ,sensor problems ,or the Turbo itself ?
    I don't know where to start ,if anyone could assist ,that would be awesome
  2. Re: Audi A4 b7 54 plate in Limp mode
    1840 Post(s)
    It is over boosting and in the vast majority of cases this is a clogged turbo which will need a rebuild, it is not a particularly bad or expensive job on this model.
  3. Re: Audi A4 b7 54 plate in Limp mode
    Feb 2019
    Scotland
    That sounds like it could be the case @Crasher , as I haven't been using the car for long trips ,only 2 mile return trips to work & maybe 20 mile trips at the weekend .
    Do you think it's worth while trying a can of turbo cleaner 1st ,then if that fails I should strip down the Turbo?
    It's a 2.0TDI ,thanks for speedy reply
  4. Re: Audi A4 b7 54 plate in Limp mode
    1840 Post(s)
    Quote Originally Posted by BILYTYGR View Post
    These cure in a bottle snake oil treatments are about as much use as rubbing a bar of chocolate on the bonnet....
  1. Please Help Audi A6 C7 2.0 TDI 190 limp mode
    By nathanc31 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-11-2018, 02:58 PM
  2. Please Help Audi 1.9 Tdi B6 Limp mode
    By Anton98 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2013, 04:12 PM
  3. "Limp Mode" - Audi A4 2002 2.0 Sport in Shoutdown Mode
    By ARJ230580 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-09-2012, 11:14 PM
  4. Audi A3 170 TDI - DPF / Limp mode problems
    By fufoo in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2010, 09:54 PM
  5. Audi A4 limp mode VAG scan
    By cameronmk2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-06-2010, 11:57 AM
