Thread: Humidity query.
  1. Humidity query.
    Jun 2016
    Devon
    High humidity levels this time of year (88% today) so as with previous older cars of the Eighties and Nineties I regularly sprayed Duck Oil on the relevant electrical parts which always worked fine. However not being at all mechanically minded no idea where and what to spray on my 2003 A4 2litre FSI Avant as having starting problems, the latest last week with a relay in the ECU the inside of which had green marks everywhere.
    Any advice much appreciated thanks....
    1982 Type 43 Audi 100 GL5E
    1984 Type 43 100 CS two tone
  2. Re: Humidity query.
    Apr 2018
    N.Ireland
    9 Post(s)
    Dielectric grease
  3. Re: Humidity query.
    Jun 2016
    Devon
    Sounds interesting how and where would you apply it ?
  4. Re: Humidity query.
    Apr 2018
    N.Ireland
    9 Post(s)
    get a small rush and paint it on, you'll find that some of your plugs already have it on them, door loom connections etc.
  5. Re: Humidity query.
    Jun 2016
    Devon
    Thanks will give it a go....
    Regarding humidity in cars generally especially classics during the winter months and the start up problems I've recently been having, I began leaving a weather station in the car overnight also displaying humidity levels the first reading at the end of January showing 84% which was way over the top as it should always be roughly between 50% and 70%. So looked on Amazon for a Hygrometer and mistakenly as it turned out chose a Chinese one which was useless cheaply made and hopelessly incorrect when comparing with my own one.
    What I didn't know at the time was that mine was an analogue hygrometer whereas the Chinese one was an ordinary hygrometer powered by a small battery, so because the instruction leaflet was the usual Chinese to English gibberish anyway got a refund from Amazon. Then after a bit of research I've just bought an analogue one which can be manually set to the correct pressure at will as in the link below whereas the battery ones as far as I know can't.
    No expert so for what it's worth....
    Lantelme 4127 Thermometer / Hygrometer Analogue Combination Machine for Interior and Exterior Use. Thermohygrometer: Amazon.co.uk: Garden & Outdoors
  6. Re: Humidity query.
    Apr 2018
    N.Ireland
    9 Post(s)
    I work in the industry and humidity is a big 'consideration' to say the least... we monitor humidity and test in various environments generally 85/85 should be fine for a well made product but obviously time takes its tole. Inside your vehicle for an easy and reusable fix i would use a bag of moisture absorbent, you can heat it and reuse it. best of luck with the tests its a tough game!
  1. A5 2013 FL vcds fault humidity sensor (g260)
    By Audidua in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 02-01-2018, 08:17 PM
  2. Please Help Air con, Horn, humidity sensor, auto-dim doesn't work
    By soupknife in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2015, 03:25 PM
  3. Air con query
    By Inspector Beetle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-06-2012, 12:25 PM
  4. Humidity and heater
    By Bar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-05-2008, 11:42 AM
  5. Sat Nav query...
    By tricky69 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-11-2007, 05:15 PM
