Hi All,
I have a MK6 Golf which has ACC. The rear shocks I have already replaced once and they are now leaking again so I need to replace them. The problem is you can only purchase them from VW (OEM) and as they come with the electronic adjustment they are over £500 for the pair. Does anyone know of any alternatives here? I had heard rumours that there would be other aftermarket versions coming soon and also that you could fit a standard shock and then plug a device onto the then redundant leads. I assume then you would need to use VCDS to code our faults?
Any advice/input would be great from anyone who has experienced this. I have priced around half the country and I cannot find much cheaper than £500!
