Thread: Locking Wheel Bolt Removal
Results 1 to 10 of 13
  1. Locking Wheel Bolt Removal [SOLVED]
    Feb 2019
    Surrey
    I've just bought a 1997 A4 1.8T, but the vendor has lost the key to remove the locking wheel bolts.
    Has anyone tried any of the nut and bolt removal sets?
    Thanks.
  2. Re: Locking Wheel Bolt Removal
    Aberdeen
    63 Post(s)
    You could try Audi for a new one.
  3. Re: Locking Wheel Bolt Removal
    Feb 2019
    Surrey
    Quote Originally Posted by Scott K View Post
    Yes, they can supply a key, but they say it is only available with a set of bolts at a cost of £72.
    Does anyone know whether the sticker on the inside cover of the service booklet identifies the key code?
    1997 A4 1.8T
  4. Re: Locking Wheel Bolt Removal
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    That sounds like reasonable value compared with the alternatives of hoping the "hammer on" removers fit, getting someone to tack-weld a regular nut on top, drill for stud extractor, etc. If you remove them destructively what does a replacement set of bolts cost?
    A quick look at the full codes for our VW (which is a lot more detailed than those in the book) says nothing about key pattern /code.
  5. Re: Locking Wheel Bolt Removal
    Feb 2019
    Surrey
    Quote Originally Posted by VAG-Abound View Post
    Yes, I agree, I'd rather pay the Audi price and get them off in a non-destructive manner. However, having asked Audi to order them, they then told me they couldn't identify the key pattern from the VIN. They were very helpful though, and the Parts Manager even drove to my house with a set of master keys to try to identify the correct one. None of them fitted though. Back to square one.
    1997 A4 1.8T
  6. Re: Locking Wheel Bolt Removal
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Is it the type with the regular splines / zig-zag around the inside of a "cup", or with the wiggly path on the top surface?
    Can you recognise it from resources like this: Products Management System and VAG Audi VW Seat Skoda Locking Wheel Nut Key 51-62 6-17 Point Ribs Splines ABC | eBay?
  7. Re: Locking Wheel Bolt Removal
    Mar 2016
    Minervois, France
    53 Post(s)
    The security wheel bolts on old Alfas have cylindrical heads with various numbers of grooves, randomly spaced.
    The "keys" to undo them have corresponding pins embedded in the cup, to match the grooves.
    An Alfa agent I used had a "master key" to undo the bolts. He had knocked out all the pins in a spare key, except one, which engaged any one of the grooves in any bolt head.
    If you have the type of bolts which need a male spline to fit them, it must be possible to make up something to jam inside the recess and engage at least one or two of the grooves.
    This is the type of key used. In your case, you could find a cylindrical bar to fit tightly inside the splined recess, file grooves in the end, corresponding to the splines, and drive one or more steel pins into the grooves.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  8. Re: Locking Wheel Bolt Removal
    Feb 2019
    Markinch
    Called out RAC when I managed to have a puncture & no locking wheel nut adaptor key to be found. Mechanic had a tool that removed the nut without damaging it. Cost £5 and you get to keep the tool head which I have used several times since. (Wavey type nut head)
  9. Re: Locking Wheel Bolt Removal
    Feb 2019
    Surrey
    It's the type with splines. It has 8 splines so the '53 / 8 PT' item looks as though that might be the one.
    Thanks very much for the steer.
    1997 A4 1.8T
  10. Re: Locking Wheel Bolt Removal
    Mar 2016
    Minervois, France
    53 Post(s)
    Quote Originally Posted by stu_rat View Post
    You're very lucky, better buy it quickly
    My tool has 9 splines, I intended buying a spare, but no-one selling them on Ebay at present has this, except one seller, who wants £11.99 plus £12 postage.
  1. How To Audi A6 2003 spline type locking wheel bolt key - work out the code!
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-12-2017, 06:39 PM
  2. Locking wheel nut removal
    By mrdannyaitch in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-03-2016, 06:26 PM
  3. Locking Wheel Bolt Keys
    By Redbenson111 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2013, 06:09 PM
  4. Golf Plus 2005 wheel bolt cap removal tool
    By EmuGriff in forum Wheels and Tyres
    Last Post: 11-02-2012, 11:49 AM
  5. HELP! Locking Wheel Nut Removal
    By ianbrown_1982 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-03-2011, 12:05 AM
