Thread: 2010 vw golf 1.6 tdi cay engine code
  1. 2010 vw golf 1.6 tdi cay engine code
    Feb 2019
    Aldershot. Uk
    Hi We are new to the forum and looking for some advice
    Our sons golf wont start unless the breather hose is removed, once the hose is reconnected the engine cuts out.
    Prior to this he had very VERY low fuel - he put in 1/4 tank and drove up the dual carriageway for 7 miles without trouble, after parking up the car wouldnt restart. The disel is flowing through ok. The breakdown recovery guy said his reader said low pressure at turbo.
    We replaced the turbo pressure sensor
    We sought advice and the acctuator seemed it could be the problem so we replaced that but still no joy.
    Our brother in law came with his reader and these are the codes popping up
    p01013
    p2463
    p2425
    p2563
    and u0121
    We had a forced dpf regen on it 7 weeks ago but haven't done much long distance driving since. Our dpf is the one that's joined to everything and a pig to remove from the car so if there is a way of cleaning it without removing it that would be a better option.
    Any advice please.
  2. Re: 2010 vw golf 1.6 tdi cay engine code
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Fv10 View Post
    p01013
    p2463
    p2425
    p2563
    and u0121
    What did you use to scan for those error code p01013 is invalid p1013.
    EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: 2010 vw golf 1.6 tdi cay engine code
    Feb 2019
    Aldershot. Uk
    Quote Originally Posted by Keithuk View Post
    EOBD II Error Codes
    Sorry it should’ve read. P0103 - I think it may have been a snap on reader but I’m not sure. Sorry
  4. Re: 2010 vw golf 1.6 tdi cay engine code
    Feb 2019
    Aldershot. Uk
  1. Access code for engine control unit...A4 '10' chassis 8K 2.0L TFSI engine code CDNCAs
    By baylissboy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-02-2015, 10:17 PM
  2. Golf Mk5 1.9 TDI - Most Reliable Engine Code
    By steadydriver in forum Golf MK5 - 2004 - 2009
    Last Post: 07-10-2014, 10:00 PM
  3. Please Help 3.0l TDI engine code CDYA 2010 A6 le mans quattro low coolant problem
    By Garry_M in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-08-2014, 11:03 AM
  4. Question Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
    By Negger in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2011, 11:26 AM
  5. Golf Mk4 1.4 Engine code Ahw
    By clbrn15 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-09-2008, 10:45 AM
