Thread: Doors need slammed shut
Results 1 to 9 of 9
  1. Doors need slammed shut
    Aug 2009
    glasgow scotland
    Doors not shutting unless a bit off force applied.
  2. Re: Doors need slammed shut
    Nov 2018
    9 Post(s)
    Yes. This is my first A6 and this may be normal for Audi and I have notice too.
    Sent from my POT-LX1 using Tapatalk
  3. Re: Doors need slammed shut
    Dec 2018
    SWEDEN
    Quote Originally Posted by reid1 View Post
    Yes thats becouse u have a motor to push the door when u open the door. Its a option to install a motor to shut the door close if its not closed
  4. Re: Doors need slammed shut
    Aug 2009
    glasgow scotland
    No mate the motors to unlock the door u open it with the handle u have to slam the door shut to close it
  5. Re: Doors need slammed shut
    Apr 2009
    Surrey
    174 Post(s)
    I would agree that the doors on my C8 require more effort to close properly than those on my previous C7. I suspect the cause may be that the C8 is better sealed than the C7 and as a result the rise in air pressure in the car is greater causing the doors to find it harder to shut
  6. Re: Doors need slammed shut
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Try it with a window cracked open, just to see.
  7. Re: Doors need slammed shut
    Aug 2009
    glasgow scotland
    Yeh that works window down have seen a mod on the bew q7 done waiting on vagcom to release info on c8 a6 to see if i can activate window drop when doors open.
  8. Re: Doors need slammed shut
    Aug 2009
    glasgow scotland
    Had car back to audi for rattle n/s/f end off dash trim told them about door was told yes you need to shut the door harder but weve cleaned and hoovered your car so was took to car and guess what ??? DOOR NOT CLOSED PROPERLY !!! . Called customer service and raised complaint was told they dont have any complaints as yet. All i can say is when my car goes in with hand brake fault will be because ive pulled away without putting it off which you can do if your belts on and the DOORS SHUT ����
  9. Re: Doors need slammed shut
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi Had this on my 65 plate A6 when new. Its much better now after 3 years, its down to the seals, they are too good !!! It became easer after about 9-12 months, the down side of quality I guess...
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Windows "short drop" - no more slamming the doors to shut them!
    By wolek76 in forum Q7 - 4M Forum - 2016 -
    Last Post: 24-04-2017, 05:51 PM
  2. Replies: 2
    Last Post: 10-05-2016, 12:53 AM
  3. Doors frozen shut this morning
    By bwoody in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2012, 09:41 PM
  4. Both rear doors stuck shut.
    By Sam in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2012, 08:18 PM
  5. Cannot shut both passenger side doors!
    By WillPassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2010, 07:54 PM
