Thread: Airbag light
Results 1 to 10 of 10
  1. Airbag light
    Jan 2019
    I'm new here. Looking for some help with my airbag light
    01222 - crash sensor side airbag; passenger side (g180)
    Any suggestions would be greatly appreciated
  2. Re: Airbag light
    Jun 2016
    Glasgow
    Sensor itself probably fault. Check wiring/connector for resistance and corrosion.
    Obviously don’t work on air bag system if unfamiliar/untrained.
  3. Re: Airbag light
    Mar 2017
    Nottingham
    9 Post(s)
    Had same problem on mine, Look at the yellow connector under the seat under the little square cut out carpet bit make sure it's got a good connection and not corroded then deleted the fault code then see if it comes back mine didn't is your golf a 3 door like mine the seat going forward and backwards all the time doesn't help
  4. Re: Airbag light
    Jan 2019
    As far as I can tell all the connectors are ok.
    So far I've checked the sensor in the door, check the wiring into the door and also wiring under the seat. I'm now at a total loss as to where I go from here. My mot has run out so I can't even take it to a garage to get checked out
  5. Re: Airbag light
    Mar 2017
    Nottingham
    9 Post(s)
    Dose it come straight back on when you clear the code
  6. Re: Airbag light
    Jan 2019
    It goes off but if I take key out of ignition then put it back in it comes back on
  7. Re: Airbag light
    Jun 2016
    Glasgow
    Quote Originally Posted by phila77 View Post
    Two things:
    *How did you check the sensor?
    *How did you check the wiring?
  8. Re: Airbag light
    Jan 2019
    Checked the sensor by swapping with drivers side. I figured if the sensor was faulty then the fault would move . Obviously I could be totally wrong. The wiring I checked continuity through the door as I've had some broken wires in the past which had been repaired and under the seat was just a visual check of the wiring and connector
  9. Re: Airbag light
    Jan 2019
    Still no luck solving this one. Had it scanned on friday with vcds and it said open or short to plus. I'm thinking it could be the wiring in the door cos the light will stay off until I open the door. I'm am at a total loss as to where to go from here. Someone must have a suggestion
  10. Re: Airbag light
    Oct 2017
    London
    12 Post(s)
    If the light stays off until you open the door it’s almost certainly a broken wire in the door, they nearly always break at the bendy rubber support casing which you can see when you open the door. Pop it out and have a look.
  1. Airbag light on.....airbag sensor location G180?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-12-2016, 04:56 PM
  2. Disconnected passenger airbag key switch, now airbag light is on
    By garmcqui in forum Golf MK7 - 2013 - 2019
    Last Post: 13-03-2016, 06:38 PM
  3. Oh the Airbag Light... 01217 Side Airbag Igniter Driver Side (N199)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2015, 02:47 PM
  4. golf mk4 tdi airbag light and abs light
    By swally34 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-06-2013, 09:12 PM
  5. Please Help Engine Light & Airbag Light stay on
    By sobberz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2010, 07:27 AM
