Thread: Boot Latch Cover
  1. Boot Latch Cover
    Jun 2018
    West Midlands
    Hi all.
    Need some help with the boot latch cover. Took mine off as I needed to remove the boot lining. Didn't remove it as carefully as I thought I was doing. Now the tabs have broken and it doesn't stay on secure. Anyone have any idea on how I can get it to stay fixed, without fixing it permanently as it needs to be removed whenever the internal boot lining needs to be removed.
  2. Re: Boot Latch Cover
    Aug 2017
    Australia
    I did the same thing to mine
    I just threaded a cable tie through it so if you need to remove it cut the cable tie and just replace it when you re install it
  3. Re: Boot Latch Cover
    Jun 2018
    West Midlands
    Thanks for the reply. Good idea. I just ended up using a bit of double sided tape. Seems to hold well, hopefully it'll come off if I need to take it off.
  1. How To VW B6 Estate- Boot latch dust cover spring flap
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-05-2015, 09:49 PM
  2. Question Boot latch opens on its own.
    By jonesrd1 in forum Golf Plus
    Last Post: 31-12-2013, 05:15 PM
  3. boot latch
    By strof in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2011, 07:44 PM
  4. a8: Boot Latch Mechanism
    By flightliner in forum Body Work, Body Styling and Body Kits
    Last Post: 14-09-2010, 05:24 PM
  5. Avant boot latch
    By jetset in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 10:43 PM
