Thread: Which brake system?
  1. Which brake system?
    Jan 2019
    Suffolk
    9 Post(s)
    I am trying to work out what brakes I have on my allroad. I have browsed some parts websites and the shiny pictures of the calipers there don't seem to match what little I can see of the calipers on mine. It doesn't help that it has taken until this evening to get to point where I could even take the wheels off, first waiting for the locking key and then to get a mate with an impact wrench to break the wheel bolts loose.
    Anyway, is there plate somewhere which says which brake system the vehicle is fitted with as there seem to be several possibilities.
  2. Re: Which brake system?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Inside first page of log book (see attached photo) or inside spare wheel well you will see all your car details - PR CODES. On logbook, Two lines down from paint code and last column (1LA in photo) is you FRONT brakes code.
    1LA = TEVES Floating Caliper front brake
    1LX = GIRLING Floating Caliper brakes
    Rear brakes have no part codes and two types - one for 6-cylinder and one for 8-cylinder. Individual part codes for caliper housing, brake carrier, pads etc.
  3. Re: Which brake system?
    Jan 2019
    Suffolk
    9 Post(s)
    Quote Originally Posted by ceilidhalfie View Post
    ...inside spare wheel well you will see all your car details...
    Thanks for the tip. The code on mine does not appear to be either of those two but is instead 1LX. Having finally managed to get the wheels off I can now see "Lucas Germany" cast into part of the caliper. Here are a couple of pics:#20190126_150207.jpg20190126_150213.jpg
  4. Re: Which brake system?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Sorry - typo which I have now corrected! When I get back to my PC I can upload an extraxt from the parts manual that will list the nos of all your front brake parts. Let me know id you want this.
  5. Re: Which brake system?
    Nov 2011
    Duns Scotland
    11 Post(s)
    Brake part nos for PR-1LX
  6. Re: Which brake system?
    Jan 2019
    Suffolk
    9 Post(s)
    Brake part nos for PR-1LX...
    Thanks, that's a big help.
  1. What Brake system on my GT TDI
    By Aaron1875 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-08-2016, 05:12 PM
  2. Air getting in brake system
    By Chrisman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-07-2011, 04:19 PM
  3. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  4. 2001-2005 A4 - Engine Check Light - Brake Boost - System too lean - System too Rich
    By A4nutter in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-10-2009, 09:45 PM
  5. Brake System
    By peyton1115 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-11-2007, 11:08 AM
