Hey there VWAudi Forum!
I'm at a bit of a stiff... hence why I am here to request help from the professionals!
Car: 1999 VW MK4 Golf 1.6SE Petrol
I have the following lights NOT illumating on key-turn: ESC, Airbag, Check Engine.
Now, I've checked all my fuses... none of them are burned out, but I am not sure how to get these to actually work? The reason I ask is I have an upcoming MOT in about a months time, I am worried I will fail. All other lights work as they should (ABS which comes on, then off as normal) and all others...
I am not sure if this will cause an MOT failure? Do I legally (In the UK/Euro) have to have the Check Engine, ESC and Airbag light turn on? If it doesn't illuminate to begin with, can they fail this?
If so, how do I repair?
I am not even sure if my car has ESC due to it being a 1999... but I can see the warning symbols engraved to the Dash Cluster...
Any help will be so so appreciated.
Thank you!
