Thread: Tdi Glow Plug Relay
Results 1 to 8 of 8
  1. Tdi Glow Plug Relay
    Edinburgh, Scotland
    I suspect that this relay isn't functioning - poor cold starting, no click sound when the glow plug light goes off, and there's no voltage at the heaters.
    But I don't know where abouts it is - can someone help me please ?
    Rob
  2. Re: Tdi Glow Plug Relay
    Can u send the year and engine code
  3. Re: Tdi Glow Plug Relay
    Edinburgh, Scotland
    Year is 2000, Tdi estate, Ambiente
    I'm not sure where to identify the engine type. It's either AGR or AHF from the Europarts website - to confuse matters further the logbook has the engine number ending in 'ALH' !
    Hope that helps us progress !
    Rob
  4. Re: Tdi Glow Plug Relay
    pos 4 on relay carrier its marked 202
  5. Re: Tdi Glow Plug Relay
    Edinburgh, Scotland
    My apologies for relying on your generosity further - but to save some fruitless searching and crawling around under the steering wheel, is that the relay plate that is part of the main fusebox (Haynes says behind the driver's side facia - I take it that's a RH drive driver!), but the book then goes on to say that some relays are at the rear of the engine compartment ?
    Many thanks indeed for your help.
    Rob
  6. Re: Tdi Glow Plug Relay
    On the main fuse box
  7. Re: Tdi Glow Plug Relay
    Edinburgh, Scotland
    And the one final question - do you know because you've had to find this out too, or do you have some magic book which tells you these sort of things ? Haynes certainly is useless for this !
    Rob
  8. Re: Tdi Glow Plug Relay
    london/ UK
    Quote Originally Posted by Rob G View Post
    Rob
    If there is a relay problem, then it will throw a fault. Whats the milleage? Ussually on tdi, the glow plugs stay on when the outside temp. is under 5 degrees and they stay energised longer the colder it gets outside...
  1. 1999 Sharan location of glow plug relay?
    By SeanieMac in forum Touran - Sharan - Caravelle
    Last Post: 29-11-2008, 10:53 PM
  2. Why glow plug relay on and off as engine revs?
    By Ants in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-01-2008, 01:32 PM
  3. Glow Plug system?
    By Juniper Berry in forum Fabia
    Last Post: 04-12-2007, 10:04 PM
  4. 2000 New Beetle Glow Plug Relay
    By noveynest98 in forum Beetle 2000-
    Last Post: 05-11-2007, 07:14 PM
  5. glow plug light
    By smiglyy in forum Archive posts
    Last Post: 27-09-2007, 08:12 PM
