Thread: Audi 2.0 TDI 2011 leaking coolant
  1. Audi 2.0 TDI 2011 leaking coolant
    Jan 2019
    Atherton, UK
    Hi, I’m new to this forum and looking for a bit of advice. I have a Audi A3 2.0TDI 2011 and a week ago the coolant light came came on on my car. After checking I needed to top my car up. Since then it seems to need topping up with a litre or so of coolant every 8-10 miles. The car itself has done 71,700 miles and I have to admit I haven’t had a new belt or water pump fitted....that was getting booked in early next month to be done. It doesn’t seem to be leaking when the car is at a standstill, if it is it’s very minimal, and only when it’s moving. My father in law has had a quick look under the bonnet and can’t see anything obvious but he says it seems to be leaking from the underneath towards the back of the engine but he couldn’t be too sure. Has anyone else had any similar experiences? I am still driving my car (be it as little as possible but I have no other means to get to work – only a 16 mile round trip) and keeping and eye on the temperature gauge, It isn’t heating up any quicker than usual and isn’t getting any hotter than usual. I am just having to top my car up every morning with about 2 litres of water before I set off for work.
  2. Re: Audi 2.0 TDI 2011 leaking coolant
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Hi and welcome. You might have better luck / quicker response if you repost here:
    Audi A3 - 8P - 2004 - 2012
  3. Re: Audi 2.0 TDI 2011 leaking coolant
    Jul 2017
    northampton uk
    hi new to all this just had head gasket blow through coolant line tested for exhaust fumes in coolant.
    have you tried a coolant pressure test kit? possible leaking areas could be heater matrix (wet carpets)
    egr control valve heat exchanger.
    split pipework
    head gasket
    radiator
  1. Attention Audi A8 2011 4.2 litre Diesel - Transmission Coolant Valve failure
    By MilanB in forum A8 - S8 - V8
    Last Post: 10-01-2018, 08:37 AM
  2. Replies: 6
    Last Post: 30-08-2017, 09:04 PM
  3. A4 b8 2011 leaking heater matrix
    By usmanrrana82 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2017, 02:57 PM
  4. Please Help AUDI 2.0TDI.coolant dissapear,no marks of leaking...
    By atmos in forum Audi A3 - Archive Topics
    Last Post: 17-03-2009, 05:36 PM
  5. Leaking coolant!!
    By nakhonian in forum Vento - 1994 - 1998
    Last Post: 30-12-2007, 01:16 PM
