Thread: Another car with wet Carpet:( how to remove drivers side?)
  1. Another car with wet Carpet:( how to remove drivers side?)
    Jun 2011
    Worcester
    How do,
    Got Wet carpet on the passenger side rear, looks to been collecting slowly for a while.
    issue looks to be rear water feed, hose has disconnected just under the ECU (in side the housing looks dry), Car is mostly on the drive - slopping down.
    So water wet on the front, but mostly to the rear.
    I have the passenger side trim off, both seats out (interesting - my seats are heated (got a green plug!) - but no loom to connect to in the car !!! ... possible project on the horizon).
    main trim on the gearbox tunnel off (both sides)
    Would like to lift all the carpet out and check the front drivers side - but its secured behind the peddles ? , plus the side trim is secured by the bonnet release - and does not want to budge.
    Got a de-humidifier in at the moment - after running a vax over the carpet .
    any assistance well come !
  2. Re: Another car with wet Carpet:( how to remove drivers side?)
    Dec 2015
    Scotland
    11 Post(s)
    Have a look at this and my pics on page 2 toward the very end - check that you're firewall / bulkhead drain valves are clear
    The apparent standard fitment wet rear foot well! - Page 2
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  3. Re: Another car with wet Carpet:( how to remove drivers side?)
    Jun 2011
    Worcester
    Cheers, yep checked those - all clear.
    Looks to be the Rear feed for the washer system, which has not worked for ages ..... now i know where the @@@ water had gone.
    I'm changing the bungs in the floor pad while the carpet is up, so got them all checked apart from the drivers side.
    carpet looks to be fully behind the pedals, didn't want to unbolt these ... might take the change and leave the last one.
    its had three weeks of in bits, running the de-humidifier for a few hours every other day (used two towels to mop up water - not as bad a some .. but enough)
    I've purchased image.jpg four of these from fleebay .. only 2.25 each, uses a 9v battery - going to strip two - and join the cables together for a longer length (tested and ~@@ wow its loud), plan to place it - either under the seat in the frame or under the dash. For a heads up water leak alarm. - will post more pics if anyone wants to see .
  1. Audi S5 drivers side Carpet wet and removal
    By DOMG82 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 30-12-2015, 01:10 PM
  2. Wet drivers side carpet
    By plucker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2012, 10:48 AM
  3. Help please.....Wet drivers side carpet
    By fr44s in forum Golf MK3 - 1993 - 1999
    Last Post: 30-04-2009, 11:21 AM
  4. Wet carpet - drivers side
    By kelljam80 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-02-2009, 08:37 PM
  5. drivers side rear wet carpet
    By scone888 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-01-2009, 06:33 PM
