Thread: Couple of minor but annoying issues - Nav and Assists
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Couple of minor but annoying issues - Nav and Assists
    Mar 2017
    Rochester, Kent
    7 Post(s)
    Got my 40 TDI Avant Sline in December and I really like it (came from a B9 A4 which is miles away IMHO). However, I get a couple of strange issues.
    Every other week I get (separately) the following two issues:
    1. All the navigation favourites (including the work & business locations) delete themselves
    2. The car complains that the camera is obstructed (it isn't) so then I get failure alarms for main beam assist, headlight assist, pre-sense, distance alerts, etc
    Re-adding the favourites fixes item 1 but it's annoying. Leaving the car switched off for a bit fixes item 2.
    Anyone had anything similar?
  2. Re: Couple of minor but annoying issues - Nav and Assists
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Warranty valid? Take to dealer, possibly a software issue and may need an update?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Couple of minor but annoying issues - Nav and Assists
    Mar 2017
    Rochester, Kent
    7 Post(s)
    Yeah, I'll give them a call - the only thing is that if they can't replicate it they might not do anything.
  4. Re: Couple of minor but annoying issues - Nav and Assists
    10 Post(s)
    2 has happened to me a couple of times. Both when i had parked very close to a wall in front though.
  5. Re: Couple of minor but annoying issues - Nav and Assists
    Apr 2009
    Surrey
    174 Post(s)
    Not sure if this is a fault or just how my car works. I have the 40 Sport with no options, so only have Lane Departure and Pre-Sense Front, both of which are standard. Day after i got the car I started it and got the warning that there was a problem with pre-sense, accompanied by this warning light
    Car was completely clean and after a short while the warning went. I just put it down to "one of those things". Since then however, and having driven the car, when I am driving I occassionally get this warning light, which is associated with Distance Control, and no other warning, even in the Driver Assist display
    However all the references to the light seem to imply it is only relevant to cars with ACC which I don't have so am confused if this is how Pre-Sense Front works or whether there is a fault
    On another point the Pre-Sense is obviously working as it acticated this morning in a car park going up a ramp because there was someone standing at the top of the ramp, behind a barrier on a pathway which the car clearly thought I was going to hit.
  6. Re: Couple of minor but annoying issues - Nav and Assists
    Mar 2017
    Rochester, Kent
    7 Post(s)
    I don't have ACC on my car and get the red warning above as well.
  7. Re: Couple of minor but annoying issues - Nav and Assists
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by PaulDiabolo View Post
    OK Sounds like it is working as intended
  8. Re: Couple of minor but annoying issues - Nav and Assists
    10 Post(s)
    Yeah me too. It's when you are too close to the car in front.
  9. Re: Couple of minor but annoying issues - Nav and Assists
    Apr 2009
    Surrey
    174 Post(s)
    Just surprised it comes up looking like it is a fault light rather than as some sort of warning in the main display area (which what it looks like you get if you have ACC)
  10. Re: Couple of minor but annoying issues - Nav and Assists
    Jun 2012
    6 Post(s)
    Yes I get (2) now and again. On one occasion there was some frost on the windscreen so probably valid. I’ve noticed it seems to happen if you park up for a short period, a minute or two. Seems to happen when you get back in. Clears if you switch off again or sometimes by itself. As noted the red light is a proximity warning if you get to close to the car in front.
  1. Couple more new car 'issues'
    By Phil K in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2013, 06:13 PM
  2. DPF issues... Annoying
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-04-2012, 12:00 PM
  3. Number of minor but annoying problems
    By jazzzza in forum 80 - 90
    Last Post: 19-01-2010, 10:02 PM
  4. Audi Coupe - couple of minor niggles...
    By lard44 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 01-12-2008, 08:48 PM
  5. Please Help Minor issues with recently purchased 1995 A4 B5 1.8
    By Cobant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-09-2008, 01:50 PM
