Thread: Running Temperature for 1.9 TDI PD 2004
  1. Running Temperature for 1.9 TDI PD 2004
    Sep 2018
    Dawlish Devon
    Whats the normal running temp for my 1.9 TDI PD 2004? I used to have a Golf 1.9 TDI for 4 years and it had a quick warm up to 90 degrees and just stayed there without moving no matter how you drove it.
    My Touran takes longer to get to temperature and varies from 65 - 90 and does move during driving.
    I am prepared to fit a thermostat as the first course of action but would like to know how other Tourans run.
    Many Thanks...
  2. Re: Running Temperature for 1.9 TDI PD 2004
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I had a touran quite a few years ago & once up to temperature it stayed at 90 all the time.
    I've had a few cars with this engine & all were the same.
    So I would get that stat changed ASAP in this weather.
  3. Re: Running Temperature for 1.9 TDI PD 2004
    1834 Post(s)
    With VAG water temp gauges from around 1997, ignore what the temp gauge says, if you look at the measuring blocks adat with diagnostics equipment you can see the gauge says 90 when it is really 77 and still says 90 at 107! If the gauge does not go up to 90 and stay there no matter what, something is wrong such as a faulty sensor or stuck open thermostat.
  1. 4.2 V8 Running temperature.............................
    By Stuart Piper in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2013, 09:36 PM
  2. 2.5 tdi running temperature.
    By a6superman in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2010, 06:44 PM
  3. 2.5 TDi running temperature
    By fadda in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-12-2009, 01:34 PM
  4. Running temperature
    By cadoc1 in forum Audi A3 - Archive Topics
    Last Post: 24-03-2009, 01:14 PM
  5. Question Running temperature 1.9 tdi?
    By markalex73 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-06-2008, 05:16 PM
