Thread: Intermittent starting issue - Polo 1.4 TDi
  1. Intermittent starting issue - Polo 1.4 TDi
    Jan 2019
    Halifax
    Hello, hoping for some tips/pointers with this problem
    2006 Polo 1.4 tdi, won't start on some mornings, just keeps cranking. Other mornings it's absolutely fine, and will start/stop all day long. No running issues at all
    Rolled it down the drive to start it on 2 mornings this week, EML light did come on with a flashing coil. Diagnostic shows the following codes:
    16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
    17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
    The battery and crank seems strong so not looking like the alternator. Interestingly, the alternator Code was picked up on one of the service history invoices last year(before I bought the car), doesn't look like it was fixed though.
    I'm leaning towards crankshaft sensor G28, anyone out there with experience of this problem on the 1.4 tdi's?
  2. Re: Intermittent starting issue - Polo 1.4 TDi
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You need to get that G28 crank sensor changed.
    A bit of an awkward job I belive, think the starter motor needs removing for access.
    Also it's easy to round off the allen bolt for the sensor.
    Probably easiest to get you local garage to do it.
    By bigmikeyoyo in forum Golf MK5 - 2004 - 2009
    Last Post: 19-08-2016, 07:49 PM
  2. Intermittent starting issue
    By Todri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2011, 05:54 PM
  3. Polo Starting Problem (intermittent)
    By Edmund in forum Polo - Derby - Lupo - Fox
    Last Post: 18-08-2010, 08:40 AM
  4. polo 1.4 tdi - intermittent starting problem and ABS
    By maxeymoo in forum Polo - Derby - Lupo - Fox
    Last Post: 07-12-2009, 12:09 PM
  5. VW POLO Intermittent Starting Problem when Hot.
    By deanobutler in forum Polo - Derby - Lupo - Fox
    Last Post: 04-06-2008, 07:18 AM
