Thread: 2006 golf mk5 1.4gt rverse and fog light issue
  1. 2006 golf mk5 1.4gt rverse and fog light issue
    Jan 2019
    wrexham wales
    Hello
    First time posting and not great with cars. Got a lovely golf last month which has an issue that the garage I bought it from hasnt yet been able to solve. I am getting the reverse light defective rear fog light defective error. Boot works fine. no other issues. It has been in twice, the auto electrician repaired the wires in loom near hinge through solder and changed bulb and made sure they work manually, but whatever try cannot get error to disappear and hence these 2 lights will not work. He suggested that the main module needed changing but the replacement was from ebay apparently and has done the same thing when replaced. He is adamant that is the problem and is now ordering another one (hopefully not off ebay)... any other suggestions as to what can be???
    thanks
  2. Re: 2006 golf mk5 1.4gt rverse and fog light issue
    Jul 2010
    Bradford, West Yorkshire
    trace the boot wiring back through the c pillar and you will find another connector. check this for corrosion.
  3. Re: 2006 golf mk5 1.4gt rverse and fog light issue
    1836 Post(s)
    It may have silly boy racer bulbs fitted, these require recoding of the computer that controls them.
  1. Question ESP 2006 golf plus no light on dash and button off lit up
    By Mattwlkr in forum Golf Plus
    Last Post: 03-03-2019, 10:11 PM
  2. MK6 GTI Golf Third Brake Light Issue
    By Rowley102 in forum Golf MK6 - 2009 - 2013
    Last Post: 27-01-2017, 08:37 PM
  3. Question golf mk5 gti reverse light issue
    By dave_g1007 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-11-2016, 09:42 PM
  4. Mk5 (2006) golf 1.9tdi se flashing glow plug light.
    By Tanks13 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-08-2015, 12:37 PM
  5. Golf 1.4 Not starting issue can anyone shed light?
    By rimreaperjack in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2013, 04:29 PM
