Thread: Wet Carpet Driverís Side
  1. Wet Carpet Driverís Side
    Nov 2009
    Hampshire
    2007 Passat saloon 140TDi, the carpet is very wet under my feet and it not obvious where its coming in. I have put a hosepipe on the driverís door and no leaks showing on the door card, plus the carpet and insulation is dry against the sill.
    So.... where else could it be coming in? I cleaned the drains each side where the windscreen wiper motor sits, there were plenty of leaves but couldnít really tell if it was blocked before as I was just squeezing my hand under the cover.
    Any suggestions? Is the drain for the aircon on the driverís side?
    Steve
  2. Re: Wet Carpet Driverís Side
    Jan 2012
    Rustington, West Sussex UK
    22 Post(s)
    Coolant level dropping? If you have what appears to be the original header tank and it appears to be at the max level, double check by looking inside as many get stained on the inside giving the impression of it being at the correct level. If coolant is dropping could be the heater matrix otherwise I would suspect the bulkhead drain tube(s) are blocked.
    Mad Mitch
  3. Re: Wet Carpet Driverís Side
    Nov 2009
    Hampshire
    Thanks Mitch, no problems with the coolant and it would smell of anti-freeze anyway. The bulkhead drains are clear, at least now, will have to pull the carpet up I guess and see if there is anything obvious.....
  4. Re: Wet Carpet Driverís Side
    Apr 2007
    France
    9 Post(s)
    Could it be the pollen filter blocked?
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacrť | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  1. Question damp carpet in driver footwell
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 08-07-2012, 09:54 PM
  2. Please Help Wet Carpet on Passenger Side
    By Tyroaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2010, 10:03 AM
  3. Driver's side carpet
    By passat130tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-08-2009, 08:53 AM
  4. Help please.....Wet drivers side carpet
    By fr44s in forum Golf MK3 - 1993 - 1999
    Last Post: 30-04-2009, 11:21 AM
  5. Wet carpet - drivers side
    By kelljam80 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-02-2009, 08:37 PM
