Thread: 2008 v6 Tdi - How to remove air quality sensor
  1. 2008 v6 Tdi - How to remove air quality sensor
    Aug 2015
    cardiff
    A recent scan revealed the air sensor is kaput
    Address 08: Auto HVAC Labels: 7L6-907-040.clb
    Part No: 7L6 907 040 AD
    Component: CLIMAtronic R/L 4326
    Coding: 0000530
    1 Fault Found:
    01592 - Air Quality Sensor (G238)
    014 - Defective
    Are these things serviceable?
    Probably not, but worth asking
    I've tried to remove it but i cannot see how to get it out, any ideas?
    I've removed the left trim by the wipers, it appears to be under the next bit of trim (the bigger section)
    Do i need to remove this main section, or can I slide it out? (afraid of snapping something!)
  2. Re: 2008 v6 Tdi - How to remove air quality sensor
    Apr 2017
    Neverland
    6 Post(s)
    You've to remove (or turn away) the triangle shaped trim piece with the grilles on it, and the sensor is located under the wiper cowl part, about over brake fluid reservoir. You've to slide it towards the left side of the car to get it out, but unless you've tiny hands, it will be very, very hard. And it will be even harder to put it back on once replaced. You'll have to push the wiper cowl trim upward a bit (or more), which should be able to withstand that, but of course there will always the risk of breaking it, especially if it's more than a decade old.
    The replacement might not be worth the risk though, as the Air Quality Sensor is only used when the A/C is set to Automatic Recirculation (the button with the round arrow around the A on it), and does not affect neither the engine, nor other parts or functions of the Climatronic anyway.
  1. Air quality sensor/automatic re-circulation
    By lyubohar in forum Passat - B8 Forum - 2015 -
    Last Post: 10-01-2018, 02:27 PM
  2. 01592 - Air Quality Sensor (G238)
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-06-2013, 08:27 AM
  3. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  4. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  5. Passat 2008 Model How to Remove Head Unit
    By ccooool in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-03-2009, 09:08 PM
free web
stats
