Thread: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
  1. 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    Jan 2019
    France
    Hello guys,
    I been having this code for some weeks. I have a Passat 2010 B6 with 2.0 140 CR CBA Engine. So basically the coil light starts flashing and the car seems slower, not by much but I think I can feel it. It happend several times randomly, always the engine was warm and at low rpms.
    This is what I found:
    Code:
    1 Fault Found:
                   P2563 - 000 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 219821 km
                        Time Indication: 0
                        Date: 2013.06.05
                        Time: 16:05:32
                 Freeze Frame:
                        RPM: 1817 /min
                        Speed: 38.0 km/h
                        Voltage: 13.83 V
                        Lambda: 46.6 %
                        Lambda: -2.4 %
                        Bin. Bits: 00001110
                        Voltage: 2.508 V
    Another previous fault.
    Code:
    009571 - Turbocharger Boost Control Position Sensor Circuit                P2563 - 000 - Implausible Signal - MIL ON
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 2
                        Fault Frequency: 10
                        Reset counter: 255
                        Mileage: 219803 km
                        Time Indication: 0
                        Date: 2041.14.04
                        Time: 14:26:28
                 Freeze Frame:
                        RPM: 851 /min
                        Speed: 4.0 km/h
                        Voltage: 14.06 V
                        Lambda: 41.0 %
                        Lambda: -2.4 %
                        Bin. Bits: 00001110
                        Voltage: 2.736 V
    So, the Implausible Signal is the -2.4% value on the Lambda
    Here I have the full Auto Scan
    AutoScan1.txt
    And here I did a log of the Measuring Block 34 and 32 under WOT in 2nd and 3rd gear.
    LOG-01-034-032.CSV.txt
    Now, after reading several threads it looks like the most probably cause is the diaphragm in the turbo actuator is leaking (also called "vacuum unit for turbocharger")
    In the workshop manual for CBA engines:
    Code:
    Pressure canister
     With position sender for charge pressure positioner - G581-
    So I have some questions:
    1. What do you guys think?
    2. How far off I'm of the actual issue
    3. Anyone has experience changing this?
    4. Is it hard to calibrate once replaced?
    Thanks for the help!
  2. Re: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    20 Post(s)
    531 Post(s)
    Yes you need a new actuator, suck it and see......
  3. Re: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    Jan 2019
    France
    Crasher, I read so many related threads that I was wishing you reply! so.. should I buy a professional vaccum pump.. or the those from the ad on the sidebar
    Thanks!
  4. Re: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    20 Post(s)
    531 Post(s)
    I have a Mitty Vac but I use a piece of 3.2mm vac pipe and the Mk1 mouth....
  5. Re: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    Jan 2019
    France
    Hi Everyone quick update.
    I bought a vacuum tool for 15€ and tested the vacuum, there was a leak:
    Then I bought the wastegate in a VW dealership 195€ and you will need a tool similar to this one: Runtime Error cost me 6€. 2 hours to change it.
    Thanks Crasher!
  1. Replies: 6
    Last Post: 02-04-2019, 04:10 PM
  2. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-09-2018, 09:48 AM
  3. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 29-08-2018, 12:21 PM
  4. Replies: 0
    Last Post: 26-04-2018, 11:45 AM
  5. Boost Control Valve for Turbocharger
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2010, 10:32 PM
