Thread: Is my BCM faulty? - VW 2.0 TDI Touran 2011
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
  1. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #41
    Jan 2019
    London
    Have my wife to thank for lemon juice and bicarb idea, I was ready to sandpaper everything! Her hands in the photos by the way, much easier for her to undo things in the cramped engine bay! Just going to put it all back together, fingers crossed some magic happens!
  2. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #42
    Jan 2019
    London
    Hi Both!
    IT ONLY BLOODY WORKED!
    We cleaned everything, put the fuse box back in and as soon as I connected the battery, the interior lights came back on! I then started the engine, the A/C lit up and then I tested everything and it all appears to be working, central locking, windows, mirrors, radio, lights, all door sensors, the lot! Left the engine running for ages, no cutting out. We've left the car in pieces for now, putting it back together tomorrow.
    I ran a new diagnostic and it's much clearer, couple of errors about the lights because the dash is apart. I'll post more tomorrow once we've put everything together and I've run some more tests.
    So happy I can't even begin to explain!
    Thanks for all your help so far
  3. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #43
    Wonderful! Dead chuffed for you mate. Well done to the husband and wife team!
  4. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #44
    1840 Post(s)
    I had a 2010 Toerag in yesterday with odd electrical issues, the owner had stopped the current drain by pulling the radio fuse. I looked at the diagram and followed it back to the source fuse. Under the front seat is a similar idea fuse box with the same Midi fuses, the one for the right dash side fuse board was corroded as were all the ones in the lineup.
  5. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #45
    Jan 2019
    London
    Hi again, here's the latest!
    Wife and I spent a good couple of hours putting the car back together today, starting the car every now and then to make sure all was ok! Did some more testing with the meter and discovered that three aftermarket (I think) circuits with 15A inline fuses were all corroded too. So I replaced those and we weather proofed them the best we can. Just took it out for a drive with my wife following behind and all good. Everything works, tested the radio, A/C, windows, sensors, park assist, rear heated windscreen, start/stop (well tested it didn't throw an error when I turned it off and on which it used to), wipers, indicators, horn and all good. Running on the new battery after charging it last night and the start is very snappy. May as well use the new battery as I can't exactly take it back!
    Have run a new diagnostic and while it is very clear it was behaving a little weirdly, every now and then appearing to lose connection. Here's the log and like I say, as far as I can see it's all working. Would appreciate some thoughts on the couple of errors in the log
    Sunday,20,January,2019,18:02:39:39744
    VCDS Version: 18.9.1.0 (x64)
    Data version: 20190114 DS296.0
    Ross-Tech: Home
    Mileage: 126240km-78441mi Repair Order:
    Chassis Type: 1T-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4F 52 56 61 62
    69 72
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 DS HW: 03L 907 309 N
    Component: R4 2,0L EDC H24 7897
    Revision: 47H24--- Serial number: 00000000000000
    Coding: 0019003A042501080000
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_EMC20TDI01103L906018DS 003005
    ROD: N/A
    VCID: 7EF425BAE16C35BAAF-802A
    No ASAM data for: "EV_EMC20TDI01103L906018DS" (VW36)
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 333B6016092B06FBCC0E06EA90226092310150
    VCID: 76E43D9AC15C7DFAF7-8022
    Address 08: Auto HVAC (J255) Labels:. 5K0-907-044.clb
    Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000000003
    ASAM Dataset: EV_Climatroinc A01010
    ROD: N/A
    VCID: 00085B429B98434ADD-8054
    No ASAM data for: "EV_Climatroinc" (VW36 *)
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
    Part No SW: 3AA 919 475 D HW: 3AA 919 475 A
    Component: PARKHILFE PLA H04 0007
    Revision: -------- Serial number: 20401105301871
    Coding: 119201
    Shop #: WSC 00657 210 92358
    ASAM Dataset: EV_EPHVA2C000000000 001006
    ROD: EV_EPHVA2C000000000_001_VW36.rod
    VCID: 3C70EFB2B7F0E7AAC1-8068
    Address 15: Airbags Labels: 1T0-909-605.lbl
    Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
    Component: 02 AIRBAG VW8 022 0100
    Revision: 02022000 Serial number: 003K4D02JNDB
    Coding: 0012338
    VCID: 377AF09E46D6C4F22C-8062
    Subsystem 1 - Serial number: 6332QSME24062C48D
    Subsystem 2 - Serial number: 6342QSME4E090B46O
    Subsystem 3 - Serial number: 6352QSME221D195EO
    Subsystem 4 - Serial number: 6362QSME221D1C70G
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440KCE00066
    Coding: 1082140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 72EC018AA53461DADB-8026
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H07 0013
    Serial number: 0093472
    Coding: 820000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 1T0 920 971 D HW: 1T0 920 971 D
    Component: KOMBI H20 0420
    Coding: 481B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 3566FA9694DA36E23E-8060
    Address 18: Aux. Heat Labels: 1K0-815-071.clb
    Part No: 7N0 963 271 C
    Component: Zuheizer 051 2730
    Revision: 00051000 Serial number: 09022126000000
    Coding: 0000031
    VCID: 3460C79257A02FEA09-8060
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 D HW: 1K0 907 951
    Component: J533 Gateway H35 0614
    Revision: H35 Serial number: 240311F2003084
    Coding: 358003
    Shop #: WSC 00597 210 89742
    VCID: 316ECE8668B21AC262-8064
    Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H20 0420
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_ImmoU_DS_VDD_RM09 A03008
    ROD: N/A
    VCID: 6ADC19EA8DE4A91A63-803E
    No ASAM data for: "EV_ImmoU_DS_VDD_RM09" (VW36 *)
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669653178
    Coding: 010000
    VCID: 285823E25B685B0AB5-807C
    1 Fault Found
    03138 - Input AUX IN
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 204
    Mileage: 126240 km
    Time Indication: 0
    Date: 2013.06.12
    Time: 01:32:03
    Address 42: Door Elect, Driver Labels: Redir Fail!
    Part No SW: 1T0 959 701 AE HW: 1T0 959 701 AE
    Component: Tuer-SG 009 2122
    Coding: 0164533
    VCID: 7AFC29AA3544199A93-802E
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    Shop #: WSC 01324 785 00200
    Address 46: Central Conv.
    Cannot be reached
    Address 4F: Centr. Electr. II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0164533
    VCID: 479A805E3636B4725C-8012
    Address 56: Radio
    Cannot be reached
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H35 0614
    Coding: 030B185A
    VCID: 71EE0E86A8325AC222-8024
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Serial number: 00000000009373000407
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 B HW: 5K0 959 703 B
    Component: Tuer-SG 007 2102
    Coding: 0163984
    Shop #: WSC 01324 020 1012552
    VCID: 3362C48E52AE28D210-8066
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H07 0100
    Revision: 3A001001 Serial number: 00000137015630
    Coding: 4100000100000000
    VCID: 3068CB8263B813CA6D-8064
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 B HW: 5K0 959 704 B
    Coding: 0163984
    End-------------------------(Elapsed Time: 02:42)--------------------------
  6. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #46
    1840 Post(s)
    Can you manually access the controllers that come up OK in the auto scan list but not in the full scan? Is the radio a factory original unit? You are using a non Ross Tech lead me thinks?
  7. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #47
    Jan 2019
    London
    Hi Crasher,
    I forgot to click on the controllers in question during the scan! Good point, I'll try again tomorrow evening. Radio is factory default as far as I know although I did fit a non factory radio and then switch back about two years ago. The lead is not a Ross Tech, I got from ebay. It says VAG17 on one side and HEX+CAN on the other?
  8. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #48
    1840 Post(s)
    I think therin lies the problem... get a genuine lead!
  9. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #49
    Jan 2019
    London
    Hi Crasher,
    Actually, I just took another look at the lead and after peeling back the CE mark, took this picture:
    Perhaps it's more genuine that I thought!
    Wife just took the car on a 40 minute ish trip and it seems fine, all in all a productive weekend. Do you think the problems with the diagnostic could be caused by a dodgy lead, maybe it's a knock off, how would I tell?!
  10. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #50
    1840 Post(s)
    It looks genuine, you are editing quite a lot of your scan header which made me think it dodgy.
  1. Touran 2011 bluetooth
    By goe555 in forum Retrofits
    Last Post: 03-09-2019, 09:34 PM
  2. VW Touran 2011 ABS/ESP Light
    By red1 in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2016, 09:19 PM
  3. Touran 2011 SE where is the Bluetooth module?
    By Fallonjw in forum Touran - Sharan - Caravelle
    Last Post: 04-03-2015, 12:51 AM
  4. Touran Faulty key fob
    By repoker23 in forum Touran - Sharan - Caravelle
    Last Post: 24-03-2010, 10:49 PM
  5. Please Help Faulty AC in Touran
    By netdudeuk in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 04:26 PM
