Thread: Is my BCM faulty? - VW 2.0 TDI Touran 2011
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
  1. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #21
    Jan 2019
    London
    Yep, that's exactly what I read in the Haynes manual, glad I haven't totally lost the plot! I'll double check the interior fuses but I still don't understand why the interior lights don't work when the doors are open, even if the battery was really dead wouldn't they still come on?
  2. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #22
    1837 Post(s)
    Could you message me your reg?
  3. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #23
    Jan 2019
    London
    Hi Crasher,
    I think I just sent you a private message with it in, is that what you meant?
  4. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #24
    Interior lights come direct from the fuse box. Is it worth pulling this out and having a look at the terminals underneath?
    Edit : From your VagCom
    00059 - Terminal 30 for Interior Lighting
    011 - Open Circuit
  5. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #25
    Jan 2019
    London
    I had read about the terminals under the battery tray, didn't think about checking under the fuse box. I replaced the fuse box myself about two years ago after the original badly designed VW one melted!
  6. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #26
    1837 Post(s)
    I started writing a long list of what to check from looking at the wiring diagram and it all became clear, all the dead systems get their power from the midi fuse at position 8 on the front of the engine bay fuse box, the one on the CARS far left next to the inner wing with a thick 6mm CSA red wire from it. Well at least that is what each individual wiring diagram says but when you look at the schematic of the fuse box, there is no fuse 8! The fuses are listed as a strip and there are two different versions listed for your car.
  7. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #27
    I think number 8 is a fuseable link
  8. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #28
    1837 Post(s)
    Yes a midi fuse type design but it looks like a full strip version on that model.
  9. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #29
    Jan 2019
    London
    Hi Both,
    The original fuse box that I replaced did not have these strip fuses but the replacement I added does. I think that VW re-designed it when the first version melted! I have tested all the strip fuses and they are fine too. I will try and get a picture of the fuse box, probably tomorrow afternoon as I'm back a little earlier.
  10. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #30
    Quote Originally Posted by CedricTheBull View Post
    Hi Both,
    If I may be so bold (I feel emotionally invested in this car now ) could you please check the voltage at F12 with Ignition on to see if the T30 relay is juicing that rail. Ta
  1. Touran 2011 bluetooth
    By goe555 in forum Retrofits
    Last Post: 03-09-2019, 09:34 PM
  2. VW Touran 2011 ABS/ESP Light
    By red1 in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2016, 09:19 PM
  3. Touran 2011 SE where is the Bluetooth module?
    By Fallonjw in forum Touran - Sharan - Caravelle
    Last Post: 04-03-2015, 12:51 AM
  4. Touran Faulty key fob
    By repoker23 in forum Touran - Sharan - Caravelle
    Last Post: 24-03-2010, 10:49 PM
  5. Please Help Faulty AC in Touran
    By netdudeuk in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 04:26 PM
