Thread: Is my BCM faulty? - VW 2.0 TDI Touran 2011
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
  1. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    I just fitted a new ignition switch on the weekend. Absolute pig of a job. What I learned was this :
    You have to remove the steering wheel. This required a small flat blade screwdriver inserted into two holes in the back of the steering wheel which are exposed by rotating the wheel 90 degrees in either direction. There are clips that need to be pushed down to release the airbag unit. For Pete's sake disconnect the battery, both positive and negative before attempting this.
    Once this is off you also need an M12 splined socket to remove the steering wheel bolt.
    Once the wheel is off you can undo the 2 torx bolts holding the bottom cowel on.
    Be careful not to dislodge the "clockspring" behind the wheel. Maybe a bit of masking tape to hold it in place. Mine fell out and I had to wind the ribbon cable back in. I was very nearly in tears.
    I managed to remove the ignition switch without removing the barrel, but I would recommend removing the barrel if you are not sure. This requires removing the steering module (clip round the back, and one at the front you will need to insert a screwdriver to get at. Also will need to unclip the clockspring assembly from the steering column surround.
    As I say, this is a pig of a job. First, can we check that all the things that are powered on by the ignition switch are getting some volts, then no need to replace the switch!
    I have a trusty Haynes comic arriving this evening from Amazon, and will be scrutinising the ignition circuits for my own purposes but will make a list of fuses and or check points to take readings with your multimeter.
    One final point I would make, check all your fuses. There are many fuses that provide power to the ECU and associated control gear. Just a simple check of all the fuses in the fuse board next to the battery would be a quick and logical step to take. There is also a drivers side fuse board that should be examined, but I don't think there's anything in there that would matter in this context.
    Will report back later.
    Edit : This link to the fuse box layout I find very useful.
    Fuse box Volkswagen Touran
    In particular I would be looking at F4,5,6,7,9,10,11,12,16 (although as crasher says this module is working),24,26 (unless 1.6L).
  2. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    Jan 2019
    London
    Hi suityou1,
    Thank you for the link, very useful, I do have a Haynes manual and the wiring diagrams seem pretty good, assuming they are accurate of course! I've tested each fuse visually and using a multi-meter for continuity but I did order some new fuses which I might fit anyway! I'll pay particular attention to the ones you've mentioned. I''ve had the BCM and Gateway out and visually checked them but I haven't looked at the ECU. Considering this is under the windscreen is it possible this could have suffered some water damage? The passenger foot-well was soaked and there was a little water under the gateway when I first removed it, but dry as a bone inside. We have since unplugged the drainage holes under the windscreen and dried out the passenger side!
  3. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    1841 Post(s)
    I used 18.9.1 on a Seat Ibiza and a Golf 7 R today and it is fine, do the very latest update which came out today and see what that says. Who's cable is it?
  4. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    Jan 2019
    London
    Hi Crasher,
    Ok, turned out that I'd failed to update the USB drivers for the interface, this is the latest scan using 18.9.1, this is the extra information that I had with the previous version:
    Wednesday,16,January,2019,21:23:45:39744
    VCDS Version: 18.9.1.0 (x64)
    Data version: 20190114 DS296.0
    Ross-Tech: Home
    Chassis Type: 1T-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4F 52 56 61 62
    69 72
    01-Engine -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    18-Aux. Heat -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: Cannot be reached 1100
    69-Trailer -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 DS HW: 03L 907 309 N
    Component: R4 2,0L EDC H24 7897
    Revision: 47H24--- Serial number: 00000000000000
    Coding: 0019003A042501080000
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_ECM20TD0I1103L906018DS 003005
    ROD: N/A
    VCID: 7EF425BAE16C35BAAF-802A
    No ASAM data for: "EV_ECM20TD0I1103L906018DS" (VW36)
    3 Faults Found
    4996 - ROD - Unknown Error Code
    - 00 [039]
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 126237 km
    Date: 2088.14.13
    Time: 00:22:27
    4708 - ROD - Unknown Error Code
    - 00 [039]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 126237 km
    Date: 2088.14.13
    Time: 00:27:48
    8169 - ROD - Unknown Error Code
    - 00 [036]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 333B6016092B06FBCC0E06EA90226092310150
    VCID: 76E43D9AC15C7DFAF7-8022
    1 Fault Found
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:02:36
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 4096
    Count: 128
    Count: 32256
    Count: 0
    Count: 251
    Count: 0
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect. (J519) Labels: Redir Fail!
    Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
    Component: BCM PQ35 M 011 0046
    Revision: BC011001
    Coding: 48180A3B8025F1E040080080140081E441518E08426DA16064 80C7000041
    VCID: 3B72ECAEBAFEE092C8-806E
    Subsystem 1 - Part No: 1T2 955 119 A
    Component: Wischer 01021 26 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    16 Faults Found
    00059 - Terminal 30 for Interior Lighting
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:48
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    00834 - Signal for Activation of Heated Rear Window
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:52
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01320 - Control Module for Climatronic (J255)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01332 - Door Control Module; Passenger Side (J387)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01333 - Door Control Module; Rear Left (J388)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:54
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01520 - Rain and Light Recognition Sensor (G397)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:52
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    01800 - Light Switch (E1)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:49
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:58:21
    Freeze Frame:
    Term 15 Off
    Voltage: 12.25 V
    OFF
    ON
    OFF
    OFF
    OFF
    02394 - Parking Light Left Front (M1)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:00:21
    Freeze Frame:
    Term 15 On
    Voltage: 11.70 V
    ON
    ON
    ON
    OFF
    OFF
    03156 - Sensor for Anti-Theft System (G578)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:49
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    03266 - Control Circuit for Signal Horn
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:49
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    03396 - Supply voltage terminal 30 for central locking
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:49
    Freeze Frame:
    Term 15 On
    Voltage: 11.60 V
    ON
    ON
    ON
    OFF
    OFF
    Address 10: Park/Steer Assist (J791) Labels:* None
    Part No SW: 3AA 919 475 D HW: 3AA 919 475 A
    Component: PARKHILFE PLA H04 0007
    Revision: -------- Serial number: 20401105301871
    Coding: 119201
    Shop #: WSC 00657 210 92358
    ASAM Dataset: EV_EPHVA2C000000000 001006
    ROD: EV_EPHVA2C000000000_001_VW36.rod
    VCID: 3C70EFB2B7F0E7AAC1-8068
    1 Fault Found
    13632272 - Databus
    U1121 00 [009] - Missing Message
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Date: 2088.14.13
    Time: 00:27:49
    Address 15: Airbags Labels: 1T0-909-605.lbl
    Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
    Component: 02 AIRBAG VW8 022 0100
    Revision: 02022000 Serial number: 003K4D02JNDB
    Coding: 0012338
    VCID: 377AF09E46D6C4F22C-8062
    Subsystem 1 - Serial number: 6332QSME24062C48D
    Subsystem 2 - Serial number: 6342QSME4E090B46O
    Subsystem 3 - Serial number: 6352QSME221D195EO
    Subsystem 4 - Serial number: 6362QSME221D1C70G
    No fault code found.
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440KCE00066
    Coding: 1082140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 72EC018AA53461DADB-8026
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H07 0013
    Serial number: 0093472
    Coding: 820000
    7 Faults Found
    117012 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    117028 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    147464 - Terminal 15
    B1148 29 [008] - Signal Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    332564 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    332580 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    332596 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
    U0011 00 [008] - Performance
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 17: Instruments
    Cannot be reached
    Address 18: Aux. Heat Labels: Redir Fail!
    Part No: 7N0 963 271 C
    Component: Zuheizer 051 2730
    Revision: 00051000 Serial number: 09022126000000
    Coding: 0000031
    VCID: 3460C79257A02FEA09-8060
    2 Faults Found
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:48
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 243
    Time Indication: 0
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 7N0 907 530 D HW: 1K0 907 951
    Component: J533 Gateway H35 0614
    Revision: H35 Serial number: 240311F2003084
    Coding: 358003
    Shop #: WSC 00597 210 89742
    VCID: 316ECE8668B21AC262-8064
    6 Faults Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:54
    Address 25: Immobilizer (J334) Labels:* Redir Fail!
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H20 0420
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADC19EA8DE4A91A63-803E
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669653178
    Coding: 010000
    VCID: 285823E25B685B0AB5-807C
    2 Faults Found
    03138 - Input AUX IN
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:30:10
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 243
    Time Indication: 0
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: None
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    Shop #: WSC 01324 785 00200
    1 Fault Found
    03803 - Steering Angle Sensor for Steering Aid
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:27:48
    Freeze Frame:
    Battery Volts: 11.7 V
    DD
    Temperature: 10.0°C
    Count: 2
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    Address 46: Central Conv.
    Cannot be reached
    Address 4F: Centr. Electr. II (J520) Labels: Redir Fail!
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H35 0614
    Coding: 050B0500
    VCID: 6FEA08FEBE064C3234-803A
    Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H02 0220
    Serial number: 0123456789ABCDEFGHIJ
    Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J394EE20SKB13 H02 0220
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
    Component: Radio RCD510 041 0166
    Revision: 00000001 Serial number: VWZ1Z3L0741470
    Coding: 0100040004
    VCID: 26442DDA517C4D7A87-8072
    1 Fault Found
    02877 - Digital Radio Antenna (R183)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 126237 km
    Time Indication: 0
    Date: 2024.14.13
    Time: 00:28:07
    Address 61: Battery Regul. (J840) Labels: Redir Fail!
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H35 0614
    Coding: 030B185A
    VCID: 71EE0E86A8325AC222-8024
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Serial number: 00000000009373000407
    Address 62: Door, Rear Left
    Cannot be reached
    Address 69: Trailer
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    End-------------------------(Elapsed Time: 03:20)--------------------------
    One thing I do see is that the date seems to be totally wrong, in the future for most faults, does this mean anything?
    suityou1, I have also replaced all the fuses you mentioned
    Thanks again for the responses.
    Edit: Just a point to note, at the moment I don't have the switch for the headlights or the rotary control for the instrument cluster brightness connected.
  5. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    1841 Post(s)
    Get a battery charger on it, 11.6 volts is not enough BUT it will crank the starter, roll on electric autonomous cars, ohh are they going to be fun-we will be treating them like washing machines...
  6. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    Jan 2019
    London
    Hi Crasher, there are not far away! This is a new battery, I suppose we could have worn it down with all the testing? The car hasn't even been driven with this battery in it!
  7. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #17
    Having sifted through your VagCom output I can see that T30 is low or open.
    According to the diagrams, 12.42 - Starting and charging - February 2003 to April 2010
    T30 is a supply relay. This could well be giving you the low voltage on the other components mentioned (some of them at least, but I'll get to that)
    The relay is supplied from the steering column control unit. The steering column control unit is fed from the ignition switch.
    The ignition switch feeds the following terminals on the steering column control unit :
    15, P, X, 50, S
    I'm not sure how recognisable these are when you take the plug off, but certainly I would be trying to check for voltage on these pins with the ignition turned on.
    Not also that T30 feeds the Diesel Direction Injection System Control unit, but I do not see that listed among the faults. The implications of this not working are fairly obvious.
    Now onto the central locking and interior lights. I can see that all the door control units are low or open :
    These are all fed from the "Convenience System Central Control Unit" which can be found behind the glove box, which is passenger side - where you mentioned water ingress.
    In answer to your question, the ECU can fill up with water and malfunction, but your VagCom does not list any faults with the ECU itself. Of course a knackered ECU might not own up to being knackered on the VagCom, but considering none of your failing systems are part of the ECU system I think for now you should not rip off your wipers and start stripping down the under windscreen cover.
    It would nice to have a diagram from the T30 perspective, but while there is no such thing I shall pore over the remaining wiring diagrams to see if this is a common theme, perhaps T30 is the culprit for the whole shebang.
    For the mean time, try and check those voltages to the Steering Column Control unit, and look for signs of water ingress in the vicinity of the Convenience System Control Unit.
    Best of luck
    Suity
  8. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #18
    Terminal 30 is fed from a relay, R4 on the diagram 12.29.
    This is labelled "Ignition main circuits relay 1" on the web site I linked to. This relay sends power to fuse 12, Diesel Direct Injection System Control unit. With the key turned, check for voltage across fuse 12. No voltage, replace the relay.
  9. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #19
    Jan 2019
    London
    Hi Suity,
    Thanks very much for all the info, I won't get a chance to properly look until the weekend.
    The first thing I went looking for was the Convenience Control Module which used to be under the carpet in the passenger foot-well as I understand it. Are you sure it's behind the glove box, I'd assumed they'd shifted it to under the steering column for my 2011 model and thought that the BCM and CCM were one and the same? I'll feel like a right idiot if there's another module I'm yet to find! My money was on a wet CCM from the get go!
    Thanks again
  10. Re: Is my BCM faulty? - VW 2.0 TDI Touran 2011
    #20
    According to the wiring diagram for the 2011 model there is no CCM at all! For 2006-2010 there is a CCM and it says it is indeed behind the glovebox.
    For the 2010 onwards, it is Fuse 47 (30A) that feeds the Driver's door control unit, F49 that feeds the passenger's door control unit.
  1. Touran 2011 bluetooth
    By goe555 in forum Retrofits
    Last Post: 03-09-2019, 09:34 PM
  2. VW Touran 2011 ABS/ESP Light
    By red1 in forum Touran - Sharan - Caravelle
    Last Post: 04-10-2016, 09:19 PM
  3. Touran 2011 SE where is the Bluetooth module?
    By Fallonjw in forum Touran - Sharan - Caravelle
    Last Post: 04-03-2015, 12:51 AM
  4. Touran Faulty key fob
    By repoker23 in forum Touran - Sharan - Caravelle
    Last Post: 24-03-2010, 10:49 PM
  5. Please Help Faulty AC in Touran
    By netdudeuk in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 04:26 PM
