Thread: A6 stop start fault.
Results 21 to 30 of 32
  1. Re: A6 stop start fault.
    #21
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    Gear recognition sensor isn't anything to do with gear box then?. It's manual by the way. Can the abs sensors be tested in away, through vcds?.
    I'll mention the abs sensors to the garage I brought it from when it goes in, which isn't until the 29th.
  2. Re: A6 stop start fault.
    #22
    Jun 2015
    Ireland
    42 Post(s)
    Quote Originally Posted by Audiman35 View Post
    Yes, you can test abs sensor using vcds. You need connect and go to abs section where it shows the speed of the wheel. Go for quick run. All speeds should be the same. One which shows different is the guilty one!
    I donít remember exact option of my head. There is a YouTube video I used. Have a look online .
    2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  3. Re: A6 stop start fault.
    #23
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    I'll see if I can get my mate to come for a drive with the laptop connected.
    Also the fault code are stored in the engine module not in the abs module if that makes a difference.
  4. Re: A6 stop start fault.
    #24
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    My mate couldn't make it today. To test the abs sensors.
    Whilst we were out today. The fault appeared again (See attached picture).
    We also noticed that a couple of time m&s it showed 4th gear in the dis but we were in 3rd. When accelerating in 2nd the gear change indicator doesn't show 2nd to 3rd untill around 3500rpm. If you accelerate slowly it's comes up and out 2500. In all other gears it shows to change as soon as your get to about 2000. I'm sure my A5 show the gear change indicator at the same revs regardless of how fast you accelerate.
  5. Re: A6 stop start fault.
    #25
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    Cars now back at audi. Apparently it's not the first time this car has had this issue.
  6. Re: A6 stop start fault.
    #26
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    Quick update.
    Car has been at audi for just over a week now. Got a phone call saying they don't know how to fix it?. There now waiting for a response from audi Germany.
  7. Re: A6 stop start fault.
    #27
    Jan 2008
    68 Post(s)
    Wow! That's not good.
  8. Re: A6 stop start fault.
    #28
    Jun 2015
    Ireland
    42 Post(s)
    Quick update.
    Maybe they will give you a new one!
  9. Re: A6 stop start fault.
    #29
    Jan 2019
    Kings Lynn, uk
    8 Post(s)
    New one would be nice.. ha ha.
    I think I'd they can't resolve it, it will be going back to where we brought it from. As it had the fault when we brought it, even though we were assured it was just a low battery.
  10. Re: A6 stop start fault.
    #30
    Jul 2016
    Chestfield kent
    43 Post(s)
    Hope that if you reject it and get your money back you will still go for another A6, have a look at what the Audi dealer you are having it looked at, has in stock. At least it will be approved and any issue would be resolved.
  1. Please Help Audi A3 start/stop system fault
    By Traser13 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-02-2017, 03:13 PM
  2. stop start system fault.
    By marcosborne in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2013, 12:43 PM
  3. Stop Start Fault
    By MFGF in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-06-2013, 10:01 AM
  4. Question Intermittent Stop/Start fault - the saga continues
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2008, 04:32 PM
