Thread: A6 stop start fault.
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
  1. Re: A6 stop start fault.
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by Audiman35 View Post
    Car has 47000 miles on it.
    I meant the age of the battery.
    Does the mmi turning the start stop off not just bring the circled a up in the dash, not an actual fault message?.
    To protect the battery is not a fault but a regular operation. Therefore there is no additional fault message on the DIS, because the regular operation is to show the "slashed A" on the dashboard.
    The most easiest way to check whether this is the problem or not is to replace the battery with a different one, and if the problem disappears, than the case can be closed. You don't need a new one, but another one from an Audi with the same specifications. Usually a car seller can do it for you.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  2. Re: A6 stop start fault.
    Jan 2019
    Kings Lynn, uk
    9 Post(s)
    No idea on the age of the battery. I guess it's the original still.
    Reason I ask about the error message in the dash between the clocks, being different to the crossed out A is that in the manual it says that, that message appearing In the dash is an error and should be taken to the garage.
  3. Re: A6 stop start fault.
    Feb 2016
    Hungary
    113 Post(s)
    Maybe I missed it, but I still can't find your car's age. Was it built in 2011, or in 2017? It's not the same
    Can you please take a picture from the error message, or type it as it appears on the DIS?
  4. Re: A6 stop start fault.
    Nov 2018
    Liverpool
    Quote Originally Posted by AT. View Post
    I know when i had same issue in the past it basically said start/stop system deactivated restart engine manually and would cut out the engine out just like it would if the start stop was activated.
  5. Re: A6 stop start fault.
    Jan 2019
    Kings Lynn, uk
    9 Post(s)
    Car is a 2013.
    Error as it comes up in the dis is.
    Start /stop system fault. Function unavailable.
    I'll try and get a picture of it next time it comes up
  6. Re: A6 stop start fault.
    Feb 2016
    Hungary
    113 Post(s)
    Car is a 2013.
    Then the battery should be good, it's not too old.
    I think, in this case it's not a battery problem, and there should be an error code during a VCDS scan. IMHO please check for a fellow member next to you who has a VCDS, and look up the proper error code.
  7. Re: A6 stop start fault.
    #17
    Jan 2019
    Kings Lynn, uk
    9 Post(s)
    Have scanned it with vcds and no error codes are stored.
  8. Re: A6 stop start fault.
    #18
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi if you are fairly confident the battery is the issue then I would ask the garage to replace with a new one as goodwill. If that doesn't resolve the fault ask them to get it looked at by Audi and offer to pay say 75% of the battery price to show goodwill on your part. At lest you would then have a starting point in resolving it...
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  9. Re: A6 stop start fault.
    #19
    Jan 2019
    Kings Lynn, uk
    9 Post(s)
    Been out in the car today. Error came up on the dis again. Start stop system fault. Function unavailable.
    Got my mate round to scan it again. I now have the following 3 errors,
    Gear recognition sensor - inplausable signal.
    Gear recognition sensor - electrica malfunction.
    Gear recognition sensor - gear position inplausable.
    No lights came on the dash and car drive fine. Just no start stop and that annoying message.... we don't even use the start stop. Lol
  10. Re: A6 stop start fault.
    #20
    Feb 2016
    Hungary
    113 Post(s)
    In this case please refer toi the above mentioned ABS sensor fault.
  1. Please Help Audi A3 start/stop system fault
    By Traser13 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-02-2017, 03:13 PM
  2. stop start system fault.
    By marcosborne in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2013, 12:43 PM
  3. Stop Start Fault
    By MFGF in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-06-2013, 10:01 AM
  4. Question Intermittent Stop/Start fault - the saga continues
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2008, 04:32 PM
