Thread: Car settings - real or imagined?
  1. Car settings - real or imagined?
    Mar 2016
    Banbury, UK
    Economy, Comfort, Automatic, Dynamic... all mode options on the MMI car setup screen - but what do they do?
    Sure, Economy makes the gear number appear as 'E4' 'E7' etc. (mine's an automatic) and it can coast if you take your foot off the accelerator (under some circumstances).
    Automatic gears are presented as the normal 'D3' 'D6' etc.
    Dynamic gets into the sports gear settings 'S4' 'S5' etc. that are also accessible by pulling back on the gear selector stalk.
    OK, so all that's clear and obvious. My question is 'what (if anything) do these different modes actually make to anything else in the car's setup?
    Am I imagining that 'E' makes the car just be less responsive when accelerating?
    Does 'Comfort' make the car wallow and have less distinct steering, but also soften the ride? etc. etc.
    Does anyone out there know what these settings are supposed to do please? Or are they actually just smoke and mirrors?
    Many thanks!
    btw... 65-plate A6 FL 2.0 S-Line Ultra auto
  2. Re: Car settings - real or imagined?
    Nov 2018
    Liverpool
    Quote Originally Posted by Lunchtimer View Post
    Many thanks!
    I first thought it was just a gimmick when I bought my 13 plate 2.0 TDI Manual but after using each one i think the only thing it changes really is throttle responsiveness and the feel of the steering i dont think it changes to much on making it more or less efficient but thats just what i feel.
  3. Re: Car settings - real or imagined?
    Apr 2009
    Surrey
    53 Post(s)
    "E" setting also affects the climate control system to reduce fuel consumption. Suspension settings are only affected if you have the air suspension option
  4. Re: Car settings - real or imagined?
    Jul 2016
    Chestfield kent
    41 Post(s)
    Hi. Dynamic moves the shift points higher in the rev range and sharp changes, makes the steering feel a little more responsive, as said only effects suspension if you have air. Comfort moves gear changes to there lower end and appear to be softer more lazy when changing also noticed a little bit of coasting at times. Auto, what is says on the tin, depending on how you drive it adapts, I'e, foot to the floor moves shift point higher, but it can confuse itself and change down with perhaps only 1000 rpm left then changes into the gear you were in then up the box. Personally I leave it in Auto and if I need to floor it just put it in Sport by knocking the shifter backwards, it stays in Sport until you knock it backwards again, then it goes back to Auto ( drive). Hope this helps...
  5. Re: Car settings - real or imagined?
    Jan 2013
    Wessex. and Southern France
    59 Post(s)
    E also effects cruise as well as AC.
  6. Re: Car settings - real or imagined?
    Jun 2015
    Ireland
    39 Post(s)
    E = donít use it! I hate how it feels, great change is not smooth and judder at times. Only times when you want to use it is motorway, still annoying though. I drive on D and S only.
    2015 A6 S-line Black Edition 2.0 TDI ULTRA
  7. Re: Car settings - real or imagined?
    Nov 2009
    Stratford upon Avon UK
    35 Post(s)
    On the 8 speed tiptronics (BiTdi) S mode also means it will not automatically change up into 8th gear (at least not at sane road speeds) - you can force it with the paddles of course.
    I'd always assumed that for the s-Tronics they would not shift up into 7th automatically when in S mode - maybe someone can confirm.
    A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
  8. Re: Car settings - real or imagined?
    Aug 2013
    East Yorkshire
    Quote Originally Posted by ukgroucho View Post
    S-tronic gearbox does not show 7th gear in S mode.
    John
  9. Re: Car settings - real or imagined?
    Jan 2008
    65 Post(s)
    Quote Originally Posted by Odee View Post
    John
    I hate to disagree but mine does. I never have my car in anything other than S and it's in 7th most of the time with CC on at 75mph.
  1. Real world S4 mpg?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2013, 10:09 AM
  2. Real world mpg ?
    By shedracer in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-06-2013, 10:55 PM
  3. Real Tricky One This
    By Doddy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-10-2011, 12:01 PM
  4. 80 2.6 - So much nicer than I had imagined
    By Wooliefromwales in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 02-07-2010, 06:53 AM
  5. 3.2 real-life MPG?
    By toff in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-02-2008, 05:13 PM
