Thread: Q8 (4N) Coding
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Q8 (4N) Coding
    Apr 2019
    Walton on Thames, England
    I ask because it is definitely available in other countries, the US Audi site gives the setup instructions.
  2. Re: Q8 (4N) Coding
    Apr 2019
    Just did my first change and it's working.
    I want the parking brake to come on when the car is turned off.
    I went to 03-ABS Brakes, first thing I did was go to Security Access and use the code 40168. Then I went to Adaption found Automatic Parking Brake in the list and change the value from Not Active to Active.
    0 2 0
  3. Re: Q8 (4N) Coding
    Mar 2010
    31 Post(s)
    199 Post(s)
    Quote Originally Posted by Gawain View Post
    Great stuff Gawain and thanks for sharing. Really good to start collating some Q8 coding.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: Q8 (4N) Coding
    Apr 2019
    Definitely a bit slow on this one unfortunately.
  5. Re: Q8 (4N) Coding
    Jan 2016
    Leominster UK
    Afternoon - I have recently bought a 9 month old Q8 Vorsprung and despite the claims of it being the everything edition I am surprised that trailer assist on the factory towbar and park assist are not enabled. I am a resonably capable retrofitted with VCDS HEX V2 and VCP and have done, soft close, kessy, speed limit & lane assist on my wife's A6 4G. For the Q8 it looks like VCDS label files are the "at your own risk" flavour. Has anyone looked at either of these or could share a scan on a Q7 or Q8 with either. My initial scan brought up a lot of faults but shared below for interest, now cleared most of them but still looks like a dealer trip to fix some of the more persistent ones.
    I have ordered the direct tyre pressure receiver which will be my first upgrade. This seems to be reasonably well documented.
    Thursday,28,November,2019,16:44:02:23598
    VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WAUZZZF1XKD020041 License Plate:
    Chassis Type: F1-AU58 (4N2)
    Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 52 5F 61
    69 6D 74 81 82 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB DC DE
    VIN: WAUZZZF1XKD020041 Mileage: 18753km-11652miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    74-Chassis Control -- Status: OK 0000
    81-Gear Shift -- Status: OK 0000
    82-Heads Up Display -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    AC-Reductant Control -- Status: OK 0000
    BB-Door Rear Drv -- Status: Malfunction 0010
    BC-Door Rear Pass -- Status: OK 0000
    C4-DC/DC Converter -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    CC-Starter-Generator -- Status: OK 0000
    CD-Laser Scanner -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    DB-Frt Corner Rdar 1 -- Status: OK 0000
    DC-Frt Corner Rdar 2 -- Status: OK 0000
    DE-Charger 1 for mobile dev -- Status: OK 0000
    Address 01: Engine (J623-DHXA) Labels: Redir Fail!
    Part No SW: 4M8 907 401 HW: 059 907 309 L
    Component: 3.0l V6 TDI H26 0001
    Revision: CAH26---
    Coding: 2A2A4012057E050334286000000400000000000000000000
    Shop #: WSC 31414 242 00001
    ASAM Dataset: EV_ECM30TDI0114M8907401 001002
    ROD: EV_ECM30TDI0114M8907401.rod
    VCID: 6E85CE9CA012C7972BB-803A
    2 Faults Found:
    4814 - Unknown Error Code
    U3501 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    25393 - FlexRay Databus
    U0080 00 [032] - Defective
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 18290 km
    Date: 2019.11.07
    Time: 14:35:00
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 255 km/h
    Coolant temperature: 67 ∞C
    Intake air temperature: 25 ∞C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 12.280 V
    Unlearning counter according OBD: 30
    Brake light switch status-Bits 0-7: 0
    Brake test switch status-Bits 0-7: 0
    Engine status: COENG_STANDBY
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
    Part No SW: 4M8 927 158 G HW: 0D5 927 156 P
    Component: 0D5 30TDIRdW H05 1001
    Revision: --H05---
    Coding: 100000
    Shop #: WSC 31414 239 00001
    ASAM Dataset: EV_TCMALX52011 002014
    ROD: EV_TCMALX52011.rod
    VCID: 40D94024CA0601E7897-8014
    Automatic Transmission Fluid Pump:
    Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
    Component: V552 ATFP H01 0705
    Serial number: 180317000200
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
    Part No SW: 4M6 907 379 N HW: 4M6 907 379
    Component: ESP9 Premium H06 0850
    Coding: 24AA329631A40B96D39E5C95187ED6E2F5BAC9244C8CD0CB3A 186B47AF5D93
    ASAM Dataset: EV_ESP9BOSCHCMP 004011
    ROD: EV_ESP9BOSCHCMP_004_AU65.rod
    VCID: 48C95804E23639A7417-801C
    2 Faults Found:
    297728 - Transport Mode Active
    U1105 00 [032] - -
    [Transport_Mode_is_activated]
    12615680 - FlexRay Databus
    U0080 00 [040] - Defective
    [FlexRay_controller_is_not_sychronous_to_the_bus]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Mileage: 18290 km
    Date: 2019.11.07
    Time: 14:35:00
    7C 00 82 00 46 24 00 00 00 00
    Unlearning counter according OBD-OBD unlearning counter: 1E
    Address 06: Seat Mem. Pass (J521) Labels:* None
    Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
    Component: MEM-BFS 009 0042
    Serial number: 00000356876723
    Coding: 0038B2400001BE810043010101010000810000070700878700 000000000000
    Shop #: WSC 31414 050 00001
    ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
    ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
    VCID: 3D2739D0BDF46C0FE21-8068
    Valve Block 1 In Passenger Side Front Seat:
    Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
    Component: N477 VB1 BFSv H04 0011
    Serial number: SJ8001131118402580EB
    Coding: BF2F00
    Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
    Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
    Component: BCM1 MLBevo H10 0652
    Coding: 07000143C13900DD070C57889FFB8C78131B33110406009781 010A001B3316810A45090200100000000003030041081B1802 000044010104000000000000000000
    ASAM Dataset: EV_BCM1BOSCHAU651 014010
    ROD: EV_BCM1BOSCHAU651_014.rod
    VCID: 74B1DCF4CE3EED47DDF-8020
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 4M8 955 119 A HW: 4M8 955 119 A Labels: 1KX-955-119.CLB
    Component: J400FRWISCH 052 0997
    Serial number: 904853F0401825000080
    Coding: 7DC727
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
    Component: G397_RLFSS H06 0002
    Serial number: 22115216X81A955555A0
    Coding: 02005D
    Light switch:
    Subsystem 3 - Part No SW: 4K2 941 501 A HW: 4K2 941 501 A
    Component: E1 - LTM H09 0086
    Serial number: 14S09.11.1800690839
    Automatic Day Night Interior Mirror:
    Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
    Component: Y7_Innenspieg H09 0002
    Serial number: GX1CE114091823810927
    Coding: 210000
    Interior Light Module:
    Subsystem 5 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L
    Component: Dachmodul H42 0413
    Serial number: Q00659725
    Coding: 0D0104
    Electrically Adjustable Steering Column:
    Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
    Component: J866-EVLS-SG H03 0100
    Serial number: WA135181000058589407
    Coding: 0A0100
    Front windshield washer pump:
    Subsystem 7 - Part No SW: 4N0 907 605 C HW: 4N0 907 605 A
    Component: J1100/SWP H21 0015
    Serial number: 00000000001833000817
    Coding: 040000
    3 Faults Found:
    67736 - Databus
    U1123 00 [008] - Received Error Message
    [Camera sensor blocked]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 243
    Mileage: 17935 km
    Date: 2019.11.06
    Time: 06:27:04
    average_Voltage_terminals: 14.40 V
    Outside air temperature sensor-Resistance: 2.56 kOhm
    Outside air temperature sensor-Outside air temperature on CAN: 5.00 ∞C
    interior_temperature: 11.00 ∞C
    Vehicle speed: 14.47 km/h
    Terminal control-Terminal 75 status: On
    Terminal control-Terminal 15 status signal: On
    Terminal control-Terminal 15 via CAN: On
    Terminal control-Term 75: qualification: OFF
    393607 - Motor for Fresh Air / Recirculated Air Flap
    B11AF 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 12
    Reset counter: 248
    Mileage: 18525 km
    Date: 2019.11.21
    Time: 18:04:45
    average_Voltage_terminals: 12.60 V
    Outside air temperature sensor-Resistance: 0.00 kOhm
    Outside air temperature sensor-Outside air temperature on CAN: 11.50 ∞C
    interior_temperature: 27.50 ∞C
    Vehicle speed: 0.00 km/h
    393731 - Motor for Recirculation Flap
    B1092 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 17495 km
    Date: 2019.10.29
    Time: 12:22:05
    average_Voltage_terminals: 14.60 V
    Outside air temperature sensor-Outside air temperature on CAN: 13.50 ∞C
    interior_temperature: 17.50 ∞C
    Vehicle speed: 0.99 km/h
    Address 13: Auto Dist. Reg (J428) Labels:* None
    Part No SW: 4M0 907 561 L HW: 4K0 907 561
    Component: LRR4R H04 0332
    Coding: 5665FF5C78082C00010360E0000000BE4A1246484481009E00
    Shop #: WSC 31414 042 00001
    ASAM Dataset: EV_ACCBOSCHAU65X 002023
    ROD: EV_ACCBOSCHAU65X_AU58.rod
    VCID: 392F2DC0A9DC502FCE9-806C
    2 Faults Found:
    2344 - Databus
    [FAULT_CAMERA_DIRT_OBJ]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 243
    Mileage: 17935 km
    Date: 2019.11.06
    Time: 06:26:51
    Control Module temperature: 22 ∞C
    Voltage terminal 15: 13.7 V
    Velocity_vehicle_reference: 6.90 m/s
    Longitudinal_acceleration_vehicle_reference: -0.20 m/s≤
    Status_ACC_System: ACC_StandBy
    Steering_angle-Data: 73.400 ∞
    Yaw_rate-Data: 3.578 rad/s
    adjustment_calculation: On
    Misalignment angle: horiz: 0.148 ∞
    Misalignment angle: horiz: fast algorithm: 0.100 ∞
    Congestion pilot: status: OFF
    Outside air temperature: 5.00 ∞C
    Sensor blindness: radar: no blindness detected
    2343 - Databus
    [FAULT_CAMERA_DIRT_PEDEST]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 243
    Mileage: 17935 km
    Date: 2019.11.06
    Time: 06:26:51
    Address 15: Airbags (J234) Labels:* None
    Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
    Component: AirbagVW31 H09 2710
    Serial number: 003YZM01HLRV
    Coding: AACCF0C000C00000985400FFF08D41A800C5
    Shop #: WSC 31414 030 00001
    ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
    ROD: EV_AirbaVW31SMEAU65x_VW53.rod
    VCID: 4ACD620CFC3ACBB7573-801E
    Belt Pretensioner left:
    Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
    Component: BeltPretRevFL H10 0115
    Serial number: 00AI2018320353200000
    Coding: 03F001
    Belt Pretensioner right:
    Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
    Component: BeltPretRevFR H10 0115
    Serial number: 00AI2018321306600000
    Coding: 03F001
    Side Sensor Driver Front:
    Subsystem 3 - Part No SW: ----------- HW: 480 001 711 18
    Component: SideSensor_Df 001 0887
    Serial number: 3570000000051B79C53P
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 4 - Part No SW: ----------- HW: 480 001 711 18
    Component: SideSensor_Pf 001 0887
    Serial number: 3580000000011A79C53L
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 5 - Part No SW: ----------- HW: 480 032 111 18
    Component: SideSensor_Dr 002 0149
    Serial number: 351001C143E5EE60ED9X
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 6 - Part No SW: ----------- HW: 480 031 911 18
    Component: SideSensor_Pr 002 0149
    Serial number: 352001C10D1E2CD03E0A
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 7 - Part No SW: ----------- HW: 480 032 310 18
    Component: FrontSensor_D 002 0149
    Serial number: 355001C185A20E408AEG
    Coding: 2D2D2D
    Front Sensor Passenger:
    Subsystem 8 - Part No SW: ----------- HW: 480 032 310 18
    Component: FrontSensor_P 002 0149
    Serial number: 356001C149F1E9F13C1Q
    Coding: 2D2D2D
    Side Sensor B-Pillar Driver Front:
    Subsystem 9 - Part No SW: ----------- HW: 480 032 111 18
    Component: SideSens_B_Df 002 0149
    Serial number: 352001C143E5EA80AB1I
    Side Sensor B-Pillar Passenger Front:
    Subsystem 10 - Part No SW: ----------- HW: 480 031 911 18
    Component: SideSens_B_Pf 002 0149
    Serial number: 355001C10D1E2530FB27
    Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
    Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
    Component: Lenks.Modul H03 0005
    ASAM Dataset: EV_SMLSKLOAU736 007012
    ROD: EV_SMLSKLOAU736_VW53.rod
    VCID: 79AFEDC0E95C902F8E9-802C
    Address 17: Instruments (J285) Labels:* None-SRI2
    Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
    Component: FBenRDWACC--- H11 0153
    Coding: A58410E67C88060001A3E160B080680008003000
    ASAM Dataset: EV_DashBoardAU65X 001017
    ROD: EV_DashBoardAU65X_VW53.rod
    VCID: 2D0709906D94FC8F521-8078
    1 Fault Found:
    16777035 - Control module
    B2001 00 [009] - Incorrect software version
    [BAP_DoorLocking_0x0D incorrect softwareversion bap_error Incompatibel data specification]
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 206
    Mileage: 18442 km
    Date: 2019.11.08
    Time: 11:20:49
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
    Component: Gateway H14 0037
    Revision: 8P030005 Serial number: 0588P769518B26
    Coding: 02010005000486408C960000005B0132DC9A00471C00000009 7D078E10000000
    Shop #: WSC 31414 245 00001
    ASAM Dataset: EV_CGateCONTIAU491 003150
    ROD: EV_CGateCONTIAU491_003_AU58.rod
    Multi Function Steering Wheel Control Module:
    Subsystem 1 - Part No SW: 4M8 951 523 HW: 4M8 951 523
    Component: J453 MFL H07 0004
    Serial number: 20181122100820 30881
    Battery Monitoring Control Module:
    Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
    Component: J367-BDMConti H03 1050
    Serial number: 7588520200181116073C
    Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
    Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
    Component: ELV-MLBevo H05 0020
    Serial number: 18000342682014
    Coding: 8800000000000000
    ASAM Dataset: EV_ELVMarqMQBA0 002002
    ROD: EV_ELVMarqMQBA0_VW41.rod
    VCID: 34311CF48EBEAD471DF-8060
    Address 36: Seat Mem. Drvr (J136) Labels:* None
    Component: MEM-FS 009 0042
    Serial number: 00000356887363
    Coding: 00389A400001BE810003010101010000810000070700878700 000000004000
    ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
    ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
    Valve Block 1 In Driver Side Front Seat:
    Component: N475 VB1 FSv H04 0011
    Serial number: SJ80011311184025805E
    Coding: BF2F00
    Address 3C: Lane Change (J769) Labels:* None
    Part No SW: 4N0 907 566 F HW: 4N0 907 566 A
    Component: MRR_HR H12 0266
    Coding: 5FFC00
    ASAM Dataset: EV_RearRadarS1DelphAU651 001018
    ROD: EV_RearRadarS1DelphAU651_AU58.rod
    Address 42: Door Elect, Driver (J386) Labels:* None
    Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
    Component: TSG FS001 0188
    Serial number: YE007RI626569
    Coding: 001DDA42520104C2A009B436
    ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
    ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
    2 Faults Found:
    196665 - Switch for Central Locking
    B122D 29 [008] - Signal Implausible
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 8
    Reset counter: 248
    Mileage: 12981 km
    Date: 2019.09.12
    Time: 09:42:29
    196724 - Motors for Central Locking
    B122B 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 250
    Mileage: 12981 km
    Date: 2019.09.12
    Time: 09:42:28
    Address 44: Steering Assist (J500) Labels:* None
    Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
    Component: EPS_MLBEVO2BS H21 0504
    Coding: B2000101010000
    ASAM Dataset: EV_EPSVWBSAU426 009015
    ROD: EV_EPSVWBSAU426_009.rod
    VCID: 313F15E071AC986F769-8064
    Address 46: Central Conv. (J393) Labels:* None
    Part No SW: 8W0 907 064 FP HW: 8W0 907 064 DP
    Component: BCM2 MLBevo 025 0406
    Coding: 013500002FB100406309A0046C00C80203004000804F02502F 0400200504823F001F0100010F01
    ASAM Dataset: EV_BCM2HellaAU736 015015
    ROD: EV_BCM2HellaAU736_015_AU58.rod
    VCID: 0F7BB318C7D8AE9F40D-805A
    Sensor For Anti Theft Alarm System:
    Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0316
    Serial number: 000000000ZY182842VMQ
    Alarm horn:
    Subsystem 2 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
    Component: Sirene, DWA 004 0007
    Serial number: 00000000000000248300
    Rear Light Left 1:
    Subsystem 3 - Part No SW: 4M8 945 069 B HW: 4M8 945 069 B
    Component: SHL_li1 H04 0004
    Serial number: 069B1811150000037063
    Coding: 000000
    Sensor Controlled Power Rear Lid:
    Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
    Component: GEB.F.Heckoef H17 0906
    Serial number: 11315144
    Rear Light Left 2:
    Subsystem 5 - Part No SW: 4M8 945 217 F HW: 4M8 945 217 F
    Component: SHL_li2 H04 0004
    Serial number: 217F1811050000033098
    Coding: 000000
    Rear Light Right 1:
    Subsystem 6 - Part No SW: 4M8 945 070 B HW: 4M8 945 070 B
    Component: SHL_re1 H04 0004
    Serial number: 070B1811140000036935
    Coding: 000000
    Rear Light Right 2:
    Subsystem 7 - Part No SW: 4M8 945 218 F HW: 4M8 945 218 F
    Component: SHL_re2 H04 0004
    Serial number: 218F1811050000033098
    Coding: 000000
    3 Faults Found:
    65732 - Databus
    U1121 00 [008] - Missing Message
    [Engine control module: Motor_14: no signal/no communication]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 18290 km
    Date: 2000.00.00
    Time: 00:00:00
    Supply voltages-Supply voltage: Terminal 30: 12.555 V
    Supply voltages-Supply voltage Terminal 30 - 2: 12.555 V
    Supply voltages-Supply voltage Terminal 30 - 3: 12.555 V
    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
    general_additional_freeze_frame-coprocessor_spi_status: 00000000
    general_additional_freeze_frame-dataflash_status: 00000000
    general_additional_freeze_frame-interior_temperature: -50.0 ∞C
    general_additional_freeze_frame-Operating_Status: 00000000 00000000
    general_additional_freeze_frame-production_mode: not active
    general_additional_freeze_frame-reset_cause: 00000000
    general_additional_freeze_frame-Reset_counter: 0
    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
    general_additional_freeze_frame-Transport_Mode: not active
    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
    can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
    65605 - Databus
    [Brake control module: ESP_21: no signal/communication]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 18290 km
    Date: 2000.00.00
    Time: 00:00:00
    65729 - Databus
    [Brake control module: ESP_05: no signal/communication]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 18290 km
    Date: 2019.11.07
    Time: 14:35:00
    Address 47: Sound System (J525) Labels:* None
    Part No SW: 4N0 035 223 B HW: 4N0 035 223
    Component: MIB2_amp_P_D5 H01 0150
    Revision: 00000001 Serial number: AUZ8ZAJ6S00ZBS/
    Coding: 0135360A00AAAAAFAA0000010000
    ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
    ROD: EV_AMPMst16C1Gen2pALPI.rod
    VCID: 2313EFA83B503AFFF45-8076
    4 Faults Found:
    0592 - Front Left Bass Speaker
    B105F 11 [008] - Short to Ground
    [Verbindungen zu Lautsprechern Kanal 13: Kurzschluss nach Masse]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 18490 km
    Date: 2019.11.12
    Time: 13:01:27
    Voltage terminal 30: 14.0 V
    0597 - Front Right Bass Speaker
    B1062 11 [008] - Short to Ground
    [Verbindungen zu Lautsprechern Kanal 14: Kurzschluss nach Masse]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 18490 km
    Date: 2019.11.12
    Time: 13:01:27
    0607 - Loudspeaker 2 in Double-Subwoofer
    B130D 11 [008] - Short to Ground
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 18490 km
    Date: 2019.11.12
    Time: 13:01:27
    0602 - Loudspeaker 1 in Double-Subwoofer
    B130C 11 [008] - Short to Ground
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 18490 km
    Date: 2019.11.12
    Time: 13:01:27
    Address 52: Door Elect, Pass. (J387) Labels:* None
    Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
    Component: TSG BFS001 0188
    Serial number: YE007RJO12468
    Coding: 001DDA025E0104C2A009B434
    ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
    ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
    VCID: 3FDB43D8B7F87E1FF0D-806A
    Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
    Part No SW: 4K0 035 063 A HW: 4K0 035 063 A
    Component: MU-H-LND-EU 046 2470
    Coding: 0135360100000000C3111102C00800302F0001E601F008008E
    ASAM Dataset: EV_MUHigGen2pALPI 001001
    ROD: EV_MUHigGen2pALPI_AU27.rod
    VCID: 211FE5A0214C28EFE69-8074
    Data medium:
    Subsystem 1 - Part No: V03 959 804 LN
    Component: MIB2P_EU_Q219 0371
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 4M8 919 605 A HW: 4M8 919 605
    Component: DU AU536 High H41 0144
    Serial number: INX00108101800100506
    Compact Disc Database:
    Subsystem 3 - Part No: V03 959 800 EG
    Component: Gracenote2 1008
    Volume Control 1:
    Subsystem 4 - Part No SW: 4N1 919 616 A HW: 4N1 919 616
    Component: LSR-D5/C8 H33 0108
    Serial number: 00004418000227672057
    Display Unit 5 For Multimedia System:
    Subsystem 5 - Part No SW: 4N0 919 603 B HW: 4N0 919 603
    Component: DU AU651 Bot H41 0144
    Serial number: INX00112081800050718
    Media socket:
    Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
    Component: MediaConnectH 014 0133
    Serial number: 051800707102001
    3 Faults Found:
    7179 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 244
    Mileage: 12531 km
    Date: 2019.08.30
    Time: 08:48:16
    Voltage terminal 30: 12.7 V
    BAP-BAP_Function_ID: 26
    7949 - Control module
    B2001 00 [008] - Incorrect software version
    [Central locking/window (0x0D) - control module: incorrect software version - BapErr_incompatible data specification]
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 246
    Mileage: 18442 km
    Date: 2019.11.08
    Time: 11:21:02
    Voltage terminal 30: 11.6 V
    1556 - Internal Control Module Memory Check Sum Error
    B2000 87 [008] - Missing message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 247
    Mileage: 18491 km
    Date: 2019.11.13
    Time: 14:04:02
    Voltage terminal 30: 13.1 V
    Software module: status-SW_Status_Consistency: 00 00 01
    Software module: status-SW_Status_Device: NavDB
    Address 61: Battery Regul. (J1120) Labels: None
    Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
    Component: BMS_48V_LiIon H06 0108
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
    ROD: EV_BMS48VLiIonLGAU536_AU58.rod
    VCID: 290FFD80597CE0AFBE9-807C
    Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
    Part No SW: 4M0 907 383 G HW: 4M0 907 383 B
    Component: Anhaenger H33 0273
    Revision: 9A001003 Serial number: 0499625962
    Coding: 0110000202000000
    ASAM Dataset: EV_TrailFunctGener2Hella 001008
    ROD: EV_TrailFunctGener2Hella_VW27.rod
    VCID: 363526FC98C2BF5723B-8062
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
    Component: HDSG-Modul H13 0170
    Revision: -------- Serial number: A2-C737-6252-2
    Coding: 28F0
    ASAM Dataset: EV_DeckLidCONTIAU736 001016
    ROD: EV_DeckLidCONTIAU736_AU38.rod
    Address 74: Chassis Control
    Cannot be reached
    Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
    Part No SW: 4M8 713 041 A HW: 4N2 713 041 C
    Component: GSM-LL H10 0077
    Revision: 0L0D5012 Serial number: 18080448660610
    ASAM Dataset: EV_GSMWaehlZFAU736 001017
    ROD: EV_GSMWaehlZFAU736.rod
    VCID: 2A0D028C5C7AEBB7B73-807E
    Address 82: Heads Up Display (J898) Labels:* None
    Part No SW: 4M8 919 617 C HW: 4M8 919 617 C
    Component: HeadupDisplay H08 1815
    Coding: 4700E0
    ASAM Dataset: EV_HeadUpDisplAU65X 001010
    ROD: EV_HeadUpDisplAU65X_AU58.rod
    Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
    Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
    Component: zFAS Var C H09 0291
    Coding: 04C184000000000000FFD60000F0C60C1B9F76000000000000 0000000096D401009BA8000000000000000080000000000000 000000000000F980400000000000000078D0008000B0008000 80000000000080400000E0
    ASAM Dataset: EV_ZFASAU516 001003
    ROD: EV_ZFASAU516_001_AU58.rod
    VCID: 005980248A86C1E7C97-8054
    9 Faults Found:
    221284 - Front Camera for Driver Assist Systems
    C12B3 FD [008] - View Temporarily Restricted
    [temp view limitations]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 243
    Mileage: 17332 km
    Date: 2019.10.27
    Time: 18:28:39
    EyeQ temperatures-CPU: -40 ∞C
    EyeQ temperatures-VPM: 23 ∞C
    Vehicle speed: 42.51 km/h
    Front camera: blinding detection-Status: not active
    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
    Front camera: blinding detection-Glare detected: No
    Front camera: blinding detection-free view detected once: Yes
    233479 - Parking Sensor(s); Rear
    B107B F0 [008] - Function Limitation due to External Factors
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 18
    Reset counter: 250
    Mileage: 15166 km
    Date: 2019.10.16
    Time: 08:19:31
    233523 - Parking Sensor(s); Front
    B10FC F0 [008] - Function Limitation due to External Factors
    [Geber f¸r Einparkhilfe vorne - Funktionseinschr‰nkung durch Umwelteinfl¸sse]
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 15
    Reset counter: 250
    Mileage: 18 km
    Date: 2019.02.02
    Time: 21:35:48
    98337 - Databus
    [ESP_15_HMS_Notstopp_Status]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 14 km
    Date: 2019.01.09
    Time: 03:42:24
    65551 - Emergency Assistant
    C12D7 F0 [008] - Status Feedback for HMI Implausible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 14 km
    Date: 2019.01.09
    Time: 03:42:26
    Profile master status emergency assistance-Nominal status: On
    Profile master status emergency assistance-Actual status:: ERROR
    65537 - Intersection Assistant
    C12D8 F0 [008] - Status Feedback for HMI Implausible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 8
    Reset counter: 244
    Mileage: 12531 km
    Date: 2019.08.30
    Time: 08:48:16
    Profile master status intersection assistant-Nominal status: On
    Profile master status intersection assistant-Actual status:: Initializing
    65540 - Following-Distance Warning (High)
    C12DA F0 [008] - Status Feedback for HMI Implausible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Mileage: 14 km
    Date: 2019.01.09
    Time: 03:42:26
    Profile master status distance warning high-Nominal status: On
    Profile master status distance warning high-Actual status:: ERROR
    65542 - Lane Change Assistant
    C12DC F0 [008] - Status Feedback for HMI Implausible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 14 km
    Date: 2019.01.09
    Time: 03:42:26
    Profile master status lane change assistance-Mode: No error recognized
    Profile master status lane change assistance-Nominal status: On
    Profile master status lane change assistance-Actual status:: OFF
    65543 - Egress Warning
    C12DD F0 [008] - Status Feedback for HMI Implausible
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 14 km
    Date: 2019.01.09
    Time: 03:42:26
    Profile master status exit warning-Mode: No error detected terminal 15
    Profile master status exit warning-Nominal status: On
    Profile master status exit warning-Actual status:: OFF
    Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
    Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
    Component: SCR-Stg-G3H05 0006
    ASAM Dataset: EV_RDCMINERGAU736 005012
    ROD: EV_RDCMINERGAU736_VW53.rod
    VCID: 323D1AEC74AAA3770F3-8066
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
    Component: TSG HFS003 0188
    Serial number: YE007RK617541
    Coding: 000DD802000104C2A008B024
    ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
    ROD: EV_DCU2RearDriveMAXHKLO.rod
    VCID: 42DD4A2CC40A13F79F3-8016
    1 Fault Found:
    196660 - Motor for Window Regulator
    B1487 54 [008] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 18525 km
    Date: 2019.11.22
    Time: 08:43:35
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS003 0188
    Serial number: YE007RK614195
    ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
    ROD: EV_DCU2RearPasseMAXHKLO.rod
    Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
    Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
    Component: PCU10 022 0324
    ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
    ROD: EV_DCDC48V210ABOSCHAU736.rod
    VCID: 3A2D32CCACDA5B37C73-806E
    Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
    Part No SW: 4K0 907 594 AC HW: 4K0 907 594
    Component: SAD_STG_1 005 0002
    Coding: 728040053632
    ASAM Dataset: EV_SunRoofCONTIAU736 009011
    ROD: EV_SunRoofCONTIAU736_009_VW27.rod
    VCID: 75B7E1F0C544F44FEA1-8020
    Address CB: Rear Axle Steering (J1019) Labels:* None
    Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
    Component: HAL_MLBevoH08 0698
    Revision: -------- Serial number: CCC_098_B_1122_
    Coding: 42242A00
    ASAM Dataset: EV_RearAxleSteerZFAU736 010018
    ROD: EV_RearAxleSteerZFAU736_010.rod
    VCID: 6FBBD398A718CE9F20D-803A
    Address CC: Starter-Generator (----) Labels:* None
    Part No SW: 4N0 903 028 H HW: 4N0 903 028 H
    Component: BSG-HP1-65 H16 0523
    Serial number: 01121800020076
    Coding: 28000000000000
    ASAM Dataset: EV_Start48VAU651 001006
    ROD: EV_Start48VAU651_001.rod
    VCID: 303910E47AA69167797-8064
    Address CD: Laser Scanner (J1122) Labels: None
    Part No SW: 4K8 907 660 B HW: 4N0 907 660
    Component: LASER_SCANNER H36 0202
    ASAM Dataset: EV_LaserScannAU651 013013
    ROD: EV_LaserScannAU651_013.rod
    VCID: 353721F085C4B44F2A1-8060
    Address CF: Lane Chge Asst 2 (J770) Labels:* None
    Component: MRR_HL H12 0266
    Coding: 5FFC00
    ASAM Dataset: EV_RearRadarS2DelphAU651 001018
    ROD: EV_RearRadarS2DelphAU651_AU58.rod
    Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
    Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
    Component: LMS_MLBevo H11 0031
    ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
    ROD: EV_LMSLeftHELLAAU58X_AU38.rod
    VCID: 72BDDAECB42AE377CF3-8026
    Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
    ASAM Dataset: EV_LMSRightHELLAAU58X 001013
    ROD: EV_LMSRightHELLAAU58X_AU38.rod
    Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
    Part No SW: 4N0 907 669 F HW: 4N0 907 669 A
    Component: MRR_VR H12 0266
    Coding: 003000
    ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
    ROD: EV_FrontCorneRadarS1AU651_AU58.rod
    Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
    Component: MRR_VL H12 0266
    Coding: 003000
    Shop #: WSC 31414 142 00001
    ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
    ROD: EV_FrontCorneRadarS2AU651_AU58.rod
    Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
    Part No SW: 4N0 035 502 A HW: 4N0 035 502 A
    Component: WLC Front H10 0057
    Coding: 400000
    ASAM Dataset: EV_Charg1MobilDevicAU651 004001
    ROD: EV_Charg1MobilDevicAU651.rod
    VCID: 221DEAAC244A33F7FF3-8076
    End----(Elapsed Time: 02:56, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
  6. Re: Q8 (4N) Coding
    Jan 2020
    UA
    Quote Originally Posted by andyhud007 View Post
    Yeah not sure it's even possible yet.. Maybe a future release of a software update etc. Unless someone with a new q8 or A8 4n for example can confirm if it works or not on other models.
    Hi there. I can confirm that I’ve got factory enabled wireless Carplay in my new Q8 (MY2020, mid-October build)
  7. Re: Q8 (4N) Coding
    #17
    Mar 2010
    31 Post(s)
    199 Post(s)
    Quote Originally Posted by yousha View Post
    Thanks Yousha
    Are you in the UK or France?
  8. Re: Q8 (4N) Coding
    #18
    Jan 2020
    UA
    No, I’m not in UK, neither in France, but in Eastern Europe. Anyway if there is an interest of adaption /long coding setting for wireless Audi Smartphone interface and 5g wifi in concerned CU (5F) I could PM it to you.
  1. Please Help Help with coding please
    By richierichs3 in forum VCDS - Help Requests
    Last Post: 03-12-2016, 02:00 AM
  2. VAG-COM Coding
    By Troyboy9061 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-06-2015, 09:42 PM
  3. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  4. ECU Coding
    By toniz in forum VCDS - Help Requests
    Last Post: 13-03-2011, 07:35 AM
  5. Question key coding again!
    By Martin Burnard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-12-2008, 11:52 AM
