Thread: New Car (Engine) Burning or Leaking oil
  1. New Car (Engine) Burning or Leaking oil
    Nov 2018
    childswickham Worcestershire
    Hello
    How much oil in 1000 miles of use is normal to burn or Leak (hope not leaking)
    Car has covered 1200 miles
    James
  2. Re: New Car (Engine) Burning or Leaking oil
    Mar 2007
    Brum
    Canít say for sure but in that kind of distance Iíd expect my golf to have used non up or at least an unmeasurable amount using the dipstick.
    Iíve done over 25,000 miles in the last year and not had to top up any oil in my Ď15 plate 2.0 diesel other than the oil changes at the last 2 services.
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  3. Re: New Car (Engine) Burning or Leaking oil
    Nov 2018
    Hi Scottie
    If it uses more oil again i will take it in.
    Thankypu :-)
    James
  4. Re: New Car (Engine) Burning or Leaking oil
    Mar 2007
    Brum
    How much have you had to top up? And are you certain enough was in there in the first place?
    I donít know what the figures are for the latest engines in the Golfs but when I was having problems with my last car (a 2007 PD diesel Touran) I found out that VW had an allowance of half a litre of oil per 1000km (620 miles) on those engines and I had used 1 litre of oil in 2000 miles so below the level for any official concerns from VW.
  5. Re: New Car (Engine) Burning or Leaking oil
    Nov 2018
    Hello Scotty
    Yes it was full when i got it because i checked it.
    It uses 0-20 oil.
    Thankyou
    James
  6. Re: New Car (Engine) Burning or Leaking oil
    Dec 2009
    Waterlooville U.K.
    12 Post(s)
    I would change the oil to vw spec 504/507 5W-30
    Skoda Octavia II SE 1.9PD TDI
  7. Re: New Car (Engine) Burning or Leaking oil
    20 Post(s)
    568 Post(s)
    VAG say that anything upto 0.5 litres per 620 miles is acceptable. If you think it is exceeding that they have a special test program that is initiated in ODIS where the oil is actually weighed to determine consumption.
  8. Re: New Car (Engine) Burning or Leaking oil
    Nov 2018
    I know it is obvious But.
    If i use the incorrect oil i might as well throw the warranty into the shredder.
    0W-20 is the oil specified by vw.
    Thankyou Crasher i will bear that in mind :-)
    James
  1. 1.8T Oil Burning/Leaking
    By Skezza in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2016, 02:26 PM
  2. Please Help VW Passat 2005 Petrol 2.0l - Engine Oil Burning too quick
    By spande in forum 2.0T, TSI and TFSI - Engine
    Last Post: 16-05-2016, 01:05 AM
  3. Engine burning oil after timing belt slip + oil pump change
    By steve_v1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2016, 03:22 PM
  4. Low oil warning, EGR valve leaking oil, burning oil smell - please help!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2012, 01:51 PM
  5. 'Leaking' engine mount
    By RDI-Baz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-04-2010, 11:17 AM
