Thread: Looking to move from a C6 to a C7 thoughts?
  1. Looking to move from a C6 to a C7 thoughts?
    Dec 2015
    Scotland
    11 Post(s)
    Hi Folks,
    I'm into the 4th year of our 2008 Sline C6 2.0tdi manual Saloon. I've been looking about at replacements as its got a few things looming and some small rusty bits starting too show plus I think the C6 is really starting to show its age design wise now IMO.
    I've been looking at all sorts of cars but a C7 in a similar spec to the current car seems the best value, just wondered what people think of the C7 and anything to watch out for when buying? Budget wise its going to be low ball around £7.5k to £9k which although would get me a tidy SE I really dislike the streeing wheel and seats on the SE and don't want to go over 100k mile approx, so basically I'm looking for unicorn if I want to try and get an early Sline around 20012 -2012!
    cheers!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Looking to move from a C6 to a C7 thoughts?
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi Only one thing to say, go for a Facelift and Tech pack with online data. Good hunting...
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  3. Re: Looking to move from a C6 to a C7 thoughts?
    Jan 2018
    Sussex
    55 Post(s)
    My brother in law drives 2012 2.0 tdi estate with manual gearbox.
    Car has over 180 000 miles and is pretty problem free.
    Only problem is clutch judder what is common on manual C7's
    If you go for 3.0 tdi Chain wear and stretch is common at 120 000 plus miles.
    Its pretty big job to change and therefore expensive.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  4. Re: Looking to move from a C6 to a C7 thoughts?
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Should just be able to get an s line for that price, manual can have probs with DMF, the early auto box has an entirely unfair rep as it fits with the car perfectly and had by that time had all it's bugs ironed out. Check gb oil was changed every 38k and it's fine. Other than that so long as it's been dealer services you should be fine. Check cam belt for replacement at 5yr interval.
  5. Re: Looking to move from a C6 to a C7 thoughts?
    Jun 2015
    Ireland
    69 Post(s)
    I moved from VW CC to C7 FL 2015 2.0 ultra stronic. Got it 2 year old with 22k km on the clock. After owning it for 1.5 year and completing 48k km I had following issues:
    - passenger mirror heating fault. Replaced a mirror glass myself for 55e
    - gearbox oil sump gasket leak at 69k km. Got a goodwill from Audi and only cost 195e to replace the oil sump, gasket and fill with the fresh ATF. Regular price was 550e
    - AdBlue pump failed just after the gb gasket at 69k km as well. Also goodwill, cost to me 340e. Regular price over 800e - this seems to be a common issue for 2014-2015 cars.
    I’m on the second set of Goodyear eagle assym 3 tyres. First set last 48k km.
    I service car with Audi. I love it, obviously, it would be nicer to not have the above issues but cars break, that’s their nature...
    Good luck in finding your new ride!
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  6. Re: Looking to move from a C6 to a C7 thoughts?
    Apr 2009
    Surrey
    174 Post(s)
    Facelift is much better than pre-Facelift, but doubt you will get one on your budget. 2.0 cars with the 177bhp engine (ie non-Ultra) were impacted by the Dieselgate saga. Not a lot you can do if the car has had the work done, but may be worth looking for any that have not had the work done so yopu can avoid any potentialissues associated with the "fix". If you end up going with an auto, the non-ultra 2.0 cars have the multitronic box rather than s-Tronic. Transmission oil change at every 38k miles is essential with either auto box. Both my pre and post-FL C7 Avants have suffered with the fuel filler flap jamming. Not a lot you can do about it, if it happens it happens but something to be aware of. Personally I would be very reluctant to buy a C7 without some sort of warranty. If something goes wrong it can be very expensive to fix. At the mileage you are talking about the car will be due (or have had) a timing belt change. Factor this cost (if it has not been done) into the price you pay and also make sure they did the water pump at the same time.
  7. Re: Looking to move from a C6 to a C7 thoughts?
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by johnsimcox View Post
    On these engines fix doesn't make such a big mess and its possible rather easily to go back to older software version without fix.
    Pre-facelift front wheel drive cars with multitronic seems to work pretty well and bad reputation on it is from older versions in C5 and C6 A6 models.
    Yes, S-tronic and Multitronic has oil and filter changes at 38k miles.
    Timing belt kit interval is 5 years or 114 000 miles and is so much better to do then fight with chain on V6.
    Its good idea to keep 1k in pocket if something goes wrong with used car like this to get it back on road.
    Current cars:
  1. Question Should i be able to move the VNT actuator rod?
    By charliebrown in forum Bora - 1998 - 2005
    Last Post: 20-03-2014, 11:24 AM
  2. Please Help Car will not move
    By russtheman in forum Octavia
    Last Post: 13-08-2011, 03:53 PM
  3. Nothing to see here, move along
    By coined in forum Chat - Completely Off Topic
    Last Post: 01-10-2007, 03:55 PM
