Thread: Intake manifold flap - how do you align on a diesel with vcds? HELP!
  1. Intake manifold flap - how do you align on a diesel with vcds? HELP!
    Dec 2015
    Scotland
    10 Post(s)
    Hi folks,
    I have replaced my intake manifold flap on my 2008 A6 2.0 tdi BRE manual. I could find no settings within the Rosstech program nor online to align the new flap.
    There is a lot of chat online about aligning a throttle body on petrols and although diesels don't have a throttle body as such it is a similar part involving a flap and motor surely it needs alignment.
    I have seen after hours of hunting 2 people who say on youtube that its just plug and play, however on the (geuine) VDO box when I opened it the part had a sticker saying it needs to be programmed with OBD!
    Any thoughts or help much appreciated!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  2. Re: Intake manifold flap - how do you align on a diesel with vcds? HELP!
    Jul 2013
    52 Post(s)
    have you tried to do it with VCDS in the adaptations page.
    There should be a drop down for it.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Intake manifold flap - how do you align on a diesel with vcds? HELP!
    16 Post(s)
    384 Post(s)
    There are no adaptations......
  4. Re: Intake manifold flap - how do you align on a diesel with vcds? HELP!
    Dec 2015
    Scotland
    10 Post(s)
    Thanks for the replies, no nothing under adaptations, Crasher from your response what’s your experience in fitting this part is it just plug and play so to speak and Ecu self learns - no adaptation or coding needed!?
  5. Re: Intake manifold flap - how do you align on a diesel with vcds? HELP!
    16 Post(s)
    384 Post(s)
    Yes just fit and go, you could run it in output tests to check it works, I tend to do this before rebuilding just in case I have misdiagnosed it and there is a wiring problem instead, if the part has not been bolted down I can return it to TPS or whoever.
  1. Question Intake Manifold Flap; Audi A4 B8
    By men8idw in forum VCDS - Help Requests
    Last Post: 28-02-2015, 08:13 AM
  2. Intake Manifold Flap
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2015, 09:33 PM
  3. Intake Manifold Flap - any connection with the diesel particulate fliter?
    By caitriona in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-01-2011, 10:53 PM
  4. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  5. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
