Thread: 2005 1.6 FSI Error P2293
  1. 2005 1.6 FSI Error P2293
    Jan 2019
    manchester
    Good Morning
    I have a 1.6 FSI Golf 2005 with error cod P2293
    This could possibly be due to the CAM follower I believe, however I am struggling to find the part. My fuel pump is mounted in the same place as the following Video: Audi A3 1.6 FSi High Pressure Fuel Pump Cam Follower Tappet Change P091 - YouTube
    which seems to be different to the majority of other vehicles. Does anyone know if the following will fit? febi bilstein 37162 cam follower for high-pressure pump - Pack of 1: Amazon.co.uk: Car & Motorbike
    If not, could anyone point me in the right direction
    I also have had the EGR valve cog lose a few teeth, luckily I have moved it so it does not affect the valve opening/closing
  2. Re: 2005 1.6 FSI Error P2293
    Jan 2019
    manchester
    Apologies, the error is P2296
  3. Re: 2005 1.6 FSI Error P2293
    Jan 2019
    Poole UK
    P2296 points to a fuel pressure regulator valve problem. N276. I tend to use the Ross Tech site to obtain more information on error codes. I have the 2.0 fsi so not too familiar with the 1.6. I don't think the cam follower would throw a code if it's failing. If it's like my 2.0 fsi the follower is a mechanical part which is part of the high pressure fuel pump.
  4. Re: 2005 1.6 FSI Error P2293
    1840 Post(s)
    If you have an early BKG or BAG code engine, yes this can be a worn pump cam follower, you have to take off the pump to find out.
  5. Re: 2005 1.6 FSI Error P2293
    Jan 2019
    manchester
    CAM follower was slightly worn, but not all the way through. Still replaced anyway as I had ordered the part. Error still showing
  6. Re: 2005 1.6 FSI Error P2293
    Jan 2019
    Poole UK
    If your original error code was camfollower related You might find the light goes out after a few trips. It would be best to have the error code cleared via VCDS and see if the same error comes back.
  1. Question 2005 A3 Sportback P0226 Error
    By Grimly Fiendish in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-09-2017, 09:09 AM
  2. 1.4tsi Limp mode, fault code P2293 Fuel pressure regulator 2 performance
    By chocolatemonk in forum Touran - Sharan - Caravelle
    Last Post: 30-09-2016, 01:48 PM
  3. Question 1.4 TSI engine faults p0016/p2293 is this the Cam chain?
    By fredthedog in forum Golf MK5 - 2004 - 2009
    Last Post: 07-09-2014, 11:29 AM
  4. Question Touran Faults p0016/p2293 - Cam chain? (Same as Golf?)
    By fredthedog in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2014, 09:03 PM
  5. A3 (2005) Navigation Plus DVD read error
    By vii_voo in forum In Car Entertainment
    Last Post: 10-03-2014, 07:34 PM
