Car starts and runs fine - the only faults I can see using it are ESP and the alarm goes off 1 minute after starting it
Sunday,06,January,2019,19:29:35:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
Ross-Tech: Home
Dealer/Shop Name: Tonys
VIN: WAUZZZ4F06N108210 License Plate: HG55WBJ
Mileage: 259600km-161307mi Repair Order: Tony 6th Jan 19
Chassis Type: 4F (XXX)
Scan: 01 03 05 08 09 15 17 19 46 4F 53 61 76
VIN: WAUZZZ4F06N108210 Mileage: 259600km-161307miles
01-Engine -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 HS HW: 028 101 255 7
Component: R4 2,0L EDC G000SG 9673
Revision: --H01--- Serial number:
Coding: 0000072
Shop #: WSC 00134 210 91052
VCID: 7BF591C93A34F3999A-802E
7 Faults Found:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 13:58:15
Freeze Frame:
RPM: 945 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.00 V
Bin. Bits: 00101000
Temperature: 8.1°C
(no units): 16.0
006464 - Unlicensed Version. Not all DTCs
P1940 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:08
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 64.0
005785 - Unlicensed Version. Not all DTCs
P1699 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:08
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 0.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:09
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 16.0
053248 - Unlicensed Version. Not all DTCs
U1000 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
053250 - Unlicensed Version. Not all DTCs
U1002 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:12
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11101000
Torque: 0.0 Nm
Bin. Bits: 0 01 0
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 259580 km
Time Indication: 0
Date: 2019.01.01
Time: 14:45:22
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00101000
Torque: 0.0 Nm
Torque: 351.4 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 2C5762958FDAA42143-FFFE
4 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 258309 km
Time Indication: 0
Date: 2018.11.19
Time: 12:24:58
Freeze Frame:
Hex Value: 0x0900
Hex Value: 0x4006
Hex Value: 0x0003
Hex Value: 0x1663
Hex Value: 0x00FF
01826 - Unlicensed Version. Not all DTCs
000 - will be decoded. - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 66
Mileage: 258502 km
Time Indication: 0
Date: 2018.11.24
Time: 09:25:27
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x02A2
Hex Value: 0x0024
Hex Value: 0x017D
Hex Value: 0x00FF
00493 - Unlicensed Version. Not all DTCs
008 - will be decoded. - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 66
Mileage: 258502 km
Time Indication: 0
Date: 2018.11.24
Time: 09:25:27
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 66
Mileage: 258502 km
Time Indication: 0
Date: 2018.11.24
Time: 09:25:27
